Old 07-02-2009, 08:11 PM   #31
UU TS50
T3 TS50 075
UU TS50's Avatar
i think pic 2 would be the way to go so it directs air up from the grille
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2009, 12:04 AM   #32
Whoosha
AU DIE HARD
Whoosha's Avatar
Picture 2 will do it :
Old 08-02-2009, 12:34 AM   #33
private9
www.TUFFCARPARTS.com
private9's Avatar
Thanks mate!
Old 13-02-2009, 10:53 AM   #34
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Originally Posted by broken_suave
I had one in for a while, no difference in engine temp at all.
One thing I noticed was that, oddly, the fuel consumption was up ever so slightly with the scoop. However, response was improved in all ranges, but showed its colours in 80km/h+ overtaking.
My theory is that if more air is going into the engine, there may be more fuel required to mix with it. Can anyone confirm that?
It seems that the guys at JMM believe that the AU ECU already provides a lot of fuel, what they do is increase the airflow to match it.....
"According to Brendan, the factory computer supplies a lot of fuel, so increasing the airflow to match it is all they've had to do for some of their kits"
So anyways.....assuming I fit my EF airbox lid to the AU.....it has a larger outlet hole (EF - 80mm; AU - 55mm).....so I need to fit some 75mm/80mm piping from airbox to TB......should I use PVC? Stainless (won't this heat up the air too much and therefore not be as good)? Silicon radiator hose?? Something else???
Old 13-02-2009, 06:25 PM   #35
bloggs24
just get stainless, or get some pipe coated in hpc, it wont effect anything really, unless your just idling, the air is moving too quick to heat up.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2009, 06:41 PM   #36
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Be carefull re the PVC pipe. I was told no pipe after the airbox.
UK
Old 13-02-2009, 06:43 PM   #37
bloggs24
UK
lol, i wouldnt advise anyone to touch pvc piping on there air induction.
