#31 | ||
Next upgraded Mk1 Leopard
This is BMC's (Ex JC)
#32 | ||
T-Series Club Member Vic
Found a couple of old beam pics on my phone...
In the first two pics, the L/H beam is not right as the bulb was not mounted correctly into the projector as I must have been in too much of a rush when fitting it... These are Minimoto Bi-Xenon H1's with 5000k 35w bulbs running off Philips 35w ballasts. They are bright enough that I may as well disconnect my 60w high beams as it makes no difference at all. |
#33 | |||
[AUT-747]
Can anybody direct me how to get in contact with 'MAD', can't seem to find his user name using the search function. Cheers, Alex. Last edited by xr6tjet; 19-09-2012 at 12:35 AM. |
#34 | ||
[AUT-747]
*edit * Don't worry I found MAD on the forums through Members List.
Thanks |
#35 | ||
*update* I replaced the third pic in the previous post with a better one showing the beam pattern.
#36 | ||
[AUT-747]
Paul (MAD) sends his regards for referring me to him for the headlight mods. I will be dropping my new set of headlights for a set of B5 (Sparkling burgundy) painted bezels as soon as he lets me know when.
Cheers, Alex. |
