Old 05-01-2007, 09:57 PM   #121
bodes-sh
lol...that's right...well in that case whichever way you decide to go, get a retune and you will be very happy...also makes it easier if you go forced induction as you can just get another retune
Old 05-01-2007, 10:11 PM   #122
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by bodes-sh
mind you an edit is around $1500...b2tf is still trying to organise a group buy edit i think
It's still on, Ive just got to get my own car running right first.
RAM 1500
Old 24-05-2007, 06:18 PM   #123
sly
Sly like a G6
sly's Avatar
Originally Posted by Casper
One that was an interesting experiment was someone connecting a vacuum cleaner to their exhaust pipe. For the first 3000 odd rpm (until the volume of exhaust overtook the volume of suction) the performance gain was very noticeable as they had effectively created a massive low pressure system in the exhaust that literally sucked the exhaust gas's out of the engine and aided the charge of new fuel and air. Something to think about I guess
Maybe they could develop that into a system that uses intake air flow to power a suction pump to scavenge the exhaust gases...
Old 24-05-2007, 07:07 PM   #124
sly
Sly like a G6
sly's Avatar
Originally Posted by chief
That is $6,319 before fitting, before tuning, before an engineer looks at it. Then you may want things like larger injectors and a better fuel pump to optimise what you have got.
You don't necessarily need tuning. The AU kit includes a chiptorque chip that plugs into the ECU's J3 port.
The Snort kits are cheaper on paper, but require further parts/fabrication and tuning (and probably larger injectors and a better fuel pump to optimise...)
I've been watching FI posts in Fordmods for about a year now and come to the conclusion that there wouldn't be much difference in cost between a blower and a low-pressure turbo delivering similar peak power without internal engine mods.
I would have a go at installing a CAPA kit myself (having R&R'd McPherson struts, heads etc over the years) but wouldn't touch doing a turbo install from bits & pieces, and I couldn't have my daily driver off the road for more than a couple of days.
So for me there isn't much choice, it's a CAPA kit or nothing... unless someone here knows a workshop in Newcastle that can install and flash-tune a turbo in 2 days flat.
The only thing against the CAPA kit would be the power delivery - a (turbo) rush at 2000 rpm would be real nice. I suspect that to be totally happy with the CAPA kit I'll have to fit a higher stall converter and then have the tranny strengthened to cope with the double load of extra torque.
As it is the motor has a step in power delivery at 2400rpm - I assume a blower will just magnify this whereas a low-pressure turbo would fill in the hole between 2000 (stall speed) and 2400 rpm?
Old 24-05-2007, 07:55 PM   #125
FGII-XR6
FGII-XR6's Avatar
Originally Posted by stockoau
I personaly cant see how a blower could be more reliable? and as fair as being more freindly on the motor cocksnot. If your runing a turbo at 7psi or a blower with a 7psi pulley, no diff to motor. But you still have the option of more boost, where as with a blower the only option your left with, is replace with a turbo
a blower doesn't have the heat to dissapate like the turbo so it can be a bit friendlier on the engine there but i feel the main decision is what you want a S/C will work better off the mark as it has no lag although this isn't as bigger isue these days it still exists for outright speed the turbo is the go me if i was going to force mine i would go th S/C as i would want the grunt off the mark so it comes down to needs and wants
Old 25-05-2007, 09:22 AM   #126
StealthAu
Stall converter.
