23-10-2011, 11:45 AM | #241 | |||
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you! |
23-10-2011, 04:08 PM | #242 | ||
P6 LTD
The engine is in, well mostly. All went well except for popping off a small berak line clip on the fire wall.
BUT!!!! (there's always a but isn't there ) Those lovely "old" new engine mounts don't work!!!!! Basically, the main part of the rubber is 37mm thick whereas the "new" new engine mounts are 31mm thick. The effect is that the holes for the engine mounts don't line up. Sooooo, engine will stay on and I will change them out insitu for the other ones, one at a time. What a major PITA Here are a couple of pic's |
25-10-2011, 01:12 AM | #243 | ||
P6 LTD
Taking a step back for a moment, first up was the steering box installation. All I had to do was to fit the pitman arm and the rag joint.
And fitted And a few random pics of the engine bay Before putting the car onto all fours, I also wanted to change out the fuel and emission lines New 1/4 and 3/8" line All I did was to tape up the new pipe to the old pipe and just pulled it through. And all done And then off the jack stands and onto the ground for the first time in a long long time And in the engine went. I don't have any pics of the engine going in as a mate of mine was helping and he was somewhat pressed for time and with the problem with the engine mounts, it all had to happen pretty quickly. And the only other job that was done was fitting the console Lastly, back to the engine mounts: as I mentioned before, the ones that I had fitted initially, had to come out. In doing so, the other ones that I did not want to fit, had to be 'panel beated' to a certain extent so as to make them work. Let's just say that a fair bit of work went into them. However, once modified, they worked a treat. I dropped the tail shafts and distributors (LTD, XC & XD) today and in about 2 weeks time all should be ready including the power steering pump, carburettors as well as some zinced bolts that still need to go on the car. So, more updates when I get all of the above stuff back. |
25-10-2011, 01:27 AM | #244 | ||
P6 LTD
And now for something more technical.
The following is a rebuild of the idler pulley mostly by pics First, press out the shaft Press on the outer rim to push the shaft and bearing out of the pulley And then press out the shaft from the bearing This is then followed by pressing the new bearing onto the shaft Then press on the pulley to the shaft & bearing And lastly, press the shaft back into the bracket And then, pressing on the cover and centre popping |
25-10-2011, 07:09 AM | #245 | ||
Many thanks Paul. Now I can get that done on my car mate
25-10-2011, 08:52 AM | #246 | ||
Excellent Work !!!
25-10-2011, 09:37 AM | #247 | |||
P6 LTD
03-11-2011, 10:53 PM | #249 | ||
G'day Paull, nearly done mate, good job.
Wayne |
13-11-2011, 08:53 PM | #250 | ||
New to AFF and only saw this thread 2 weeks ago. Very impressive, the build and the sheds! Love it
This is a high quality build and can't wait to see the finished car on here and maybe in the flesh one day. |
13-11-2011, 09:16 PM | #251 | ||
Loving this build that is high attention to detail , great cobra can't wait to see the rest.
18-11-2011, 01:09 AM | #252 | ||
* 1962 XK Deluxe Sedan *
Yes mate - i fully concur with all above comments..... Sensational work.
18-11-2011, 01:56 PM | #253 | ||
T3/Sprint8
I'm so jealous of this build - well done Paull.
Just wondering once she's done - will she be a now and then weekend cruiser and show stopper at all ?
01-12-2011, 12:01 AM | #254 | ||
P6 LTD
Small update. A few things have returned
Power steering pump Air cleaner has been plastic media blasted and undercoated. It still needs a final coat in that lovely blue Distributor (the other one is for the P6 LTD that I am restoring) Driveshafts, (same as above, the longer one is for the P6 LTD) And of course, saving the best for last, the Carter Thermoqad (lots of pics here) And a few in the engine bay |
01-12-2011, 12:06 AM | #255 | ||
That has to be one of the best looking carbies I have ever seen!
01-12-2011, 12:06 AM | #256 | |||
P6 LTD
I think it will be a now and then weekend cruiser. I have made quite a few changes away from standard for the car to be judged as a starndard resto so I don't think it would do all that well. But I am certainly happy with it as I have done the car the way that I have always wanted to. |
01-12-2011, 12:08 AM | #257 | |||
P6 LTD
01-12-2011, 12:11 AM | #258 | ||
Awesome
Location: In my own little world..Everyone here knows me :)
Thanks for sharing the pics Paull. Awesome
01-12-2011, 12:15 AM | #259 | |||||||
P6 LTD
01-12-2011, 12:16 AM | #260 | |||
P6 LTD
01-12-2011, 12:57 AM | #261 | |||
XA WILD VIOLET http://www.fordforums.com.au/showthread.php?t=11272268 |
18-12-2011, 11:04 PM | #262 | ||
N/A all the way
My lust for the Cobra as a kid is why I ordered my GT new in 2004 with the blue stripes. Loved reading through this see it slowly coming to life. Thanks!!
BA GT 5.88 litres of Modular Boss Powered Muscle 300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight |
20-12-2011, 03:55 PM | #263 | ||
it has been said before but mate ...WOW what a quality build ,i have a look in every now and then to see how its going and to get some inspiration when i get to doing my xb gt back to original ,only hope i dont rush it and end up not happy with the job ,has there been anything that you have found that you wish could have been done better or differantly ...doc
21-12-2011, 01:01 PM | #264 | |||
1974 XB Falcon 500 V8, 1978 XC Falcon 500 V8, 1994 XR6 Wagon. http://i143.photobucket.com/albums/r...hoppedwagn.jpg http://i143.photobucket.com/albums/r...GN/XCSmall.jpg http://i143.photobucket.com/albums/r...XB001Large.jpg Last edited by Flogginit; 21-12-2011 at 01:02 PM. Reason: spelling error |
21-12-2011, 01:20 PM | #265 | ||
Really nice Paul.
Nearly there and looking fantastic... |
21-12-2011, 04:06 PM | #266 | |||
P6 LTD
One for the P6 LTD http://www.fordforums.com.au/showthr...1328255&page=5 And one for this car. I have been a bit slack and I have not posted up the most recent photos for the XD http://www.xfalcon.com/forum/showthr...-pursuit/page6 |
21-12-2011, 04:14 PM | #267 | |||
P6 LTD
Leaf springs to be painted properly. To have it finished by now. On the last point, I have recently changed jobs and the way it's looking, the car won't be touched for the indefinite future. Same applies to the XD and the LTD. Real bummer that. |
29-12-2011, 02:02 AM | #268 | |||
Would love to drive a beauty like this.. good luck mate.. |
29-12-2011, 04:18 PM | #269 | |||
P6 LTD
07-04-2012, 12:10 PM | #270 | ||
Hi,any updates Paul ? I was just looking at a NZ website with a resto of my late brothers Cobra 388 ....wow it is going to be one tough beast . Hope you get to drive 140 soon.
