Old 24-06-2020, 04:25 PM   #1
AussieG62013
AussieG62013's Avatar
Default Mondeo Rocker Panel Clips fix
Ok I ordered these new clips from Ford to replace the missing rocker panel clips on the passenger side but they don't clip ???
Anyone else have the same issue and have a fix for it.
https://www.dropbox.com/s/1j61y3yf45...12.21.jpg?dl=0
https://www.dropbox.com/s/fxje4c9jp0...11.57.jpg?dl=0
https://www.dropbox.com/s/ia6z0vsnlo...00.35.jpg?dl=0
https://www.dropbox.com/s/n4kmrcffz9...59.32.jpg?dl=0
I push them in and nothing ????
FORD FG MKII G6 2013
FORD Mondeo Titanium MD Hatch 2015
K&N Air Filter
AussieG62013 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2020, 05:13 PM   #2
GTLEGEND
Default Re: Mondeo Rocker Panel Clips fix
Have a look at the below attached image. You need both the pin clip and nut labelled HM1 and HM2 in the image, part numbers W716503 S300 and W716350 S300 respectively. Do you have them both?
MD Mondeo Rocker Mouldings.pdf
Old 24-06-2020, 06:18 PM   #3
AussieG62013
Attachment 103099
pin clip and nut ???? there just a clip mate HM2 that runs along the bottom HM1 is not for holding the bottom up.
K&N Air Filter
Old 24-06-2020, 09:14 PM   #4
GTLEGEND
Doesn't the clip secure into nut? i.e. you need to push them into what they call the nut. What was the part number you bought? I think you need them both to work in conjunction with each other.
W716503 S300 : https://www.ebay.com.au/itm/OEM-Genu...EAAOSw7RJeh4k6
W716350 S300: https://www.ebay.com.au/itm/Ford-OEM...frcectupt=true
Old 24-06-2020, 10:00 PM   #5
AussieG62013
If you look at the diagram you gave me HM1 goes side ways on the upper part of the rocker panel HM2 if you look at the pictures I provided clip side ways into rocker panel then your meant to push up into holes on the body of the car and they should just clip in but there not clipping in or barley at all and pop back out apparently it's common. I need to know from someone who has had the same issue and what there fix for it was. My last resort is going to a panel shop and pay more money out of my wallet.
K&N Air Filter
Old 25-06-2020, 08:04 AM   #6
adyadad
I wouldn't get them from Ford. We're missing 4 on our MD and I went to spare parts while it was getting the battery harness recall. They stated $10.80 each. For a plastic clip.
adyadad is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2020, 12:44 PM   #7
AussieG62013
Already got them mate as already stated and no one else has them in Australia good luck buying them from overseas expect them to show up in a few months if ever.
K&N Air Filter
Old 25-06-2020, 03:59 PM   #8
AussieG62013
Have it all fixed now I took it to a panel shop and discovered there was a misalignment and slight damage they fixed it all up and checked the other side for me and for added measure they used Automotive Silastic at key locations to prevent the clips popping out again as they said this is common on the MD's.
K&N Air Filter
Old 25-06-2020, 04:08 PM   #9
adyadad
Thanks for the info. Might have to try it myself. They do seem a bit loose and I'm missing a couple of clips on either side.
Old 25-06-2020, 04:20 PM   #10
AussieG62013
Good luck apperently there a real pain in the butt there easily breakable as there a very poor design. You might need to have real good access to the underneath to see everything as they had a hoist to put my car up onto.
At least I don't have to go to Bunnings now.
K&N Air Filter
Thread Tools
Display Modes
