Old 15-05-2010, 07:17 PM   #1
Falconxr68
Falconxr68's Avatar
Default sluggish feel solved
Hi guys,
I recently bought an 02 AU series 3 XR6 and realised that it felt a little sluggish (compared to my bros 01 AU2) from the take off until i put my foot down.
I searched this forum for threads that had similar problems and made a list of possible reasons and found that things such as leads, coil pack, ECU, blocked cat, fuel pump ect. could be the problem.
I got new leads and spark plugs fitted as per the advice of a mechanic which thankfully solved the problem.
The car felt so much better and responsive after that so i just wanted to post this up incase there are others out there with similar issues. having said that, this may not be the solution for everyone as it may be something else but worth the input.
Hope that helps.
Falconxr68 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 04:13 PM   #2
bo0
bo0's Avatar
Cheers for that,
My 01 XR6 is having a similar issue at the moment, has no-go when put under heavy acceleration.
Will definitely try new spark plugs first (recently replaced the leads and they were not the issue).
The Beast:
'05 E60 BMW M5 - 5L V10 Goodness!
Daily/Project:
'92 EBII Fairmont 5L Build
Old Rides:
'01 AUII XR6
'97 EL GLi
'90 EA S-Pack
bo0 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 12:32 AM   #3
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Yeh good point falcon xr68. Mine was starting to feel a bit sluggish, thought it must be the air filter, it was getting pritty dirty. New filter made no difference. Thought well maybe new plugs, but they're "only" 20,000 km old. Boy did the new plugs make a differnce, drove like new again.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2022, 04:42 PM   #4
HONK
*Honker*
HONK's Avatar
Default Re: sluggish feel solved
Also worth mentioning that the catalytic converter should be replaced around every 140,000kms, or 10 years. So if car is sluggish around 140,000km, or 280,000km, suspect that too.
- And you can buy a universal cat from ebay for $40, or a genuine one for 10x more.
Either way.
Good stuff.
Last edited by HONK; 22-12-2022 at 04:43 PM. Reason: Guess who literally just bumped a 12 year old thread... OOPS!
HONK is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2022, 06:43 PM   #5
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Lol, good heads up anyway
