21-01-2021, 10:07 AM | #1 | ||
Been looking to buy a 4x4 diesel for the last 6mth's , what a mine field.
I suppose covid didnt help LOL. Ive seen a lot of low kms cars that look like they've done a lot more than what they state. A google search confirmed my suspicions!!! You can buy a plug in scanner that can adjust the kms for 400$ odd. Apart from honest use when installing a reco, why have manufactures aloud this to happen. I,m at a loss Last edited by steves6403; 21-01-2021 at 10:08 AM. Reason: spelling |
21-01-2021, 12:19 PM | #2 | ||
What plug in scanner can do that, and to what vehicle?
21-01-2021, 12:36 PM | #3 | ||
Thailand Specials
She's been given a bit of a 'haircut'
How good are older cars, just change the cluster. |
21-01-2021, 12:55 PM | #4 | |||
If they've been used Off road or as Work Vehicles? It's quite possible that They've have Very Low Average speeds & High Engine hours relative to a Car that's spent most of It's life at Highway Speeds.. Whenever I'm Looking at a S/H Truck I always take Far more Notice of the Engines Hours than the Distance travelled.! |
3 users like this post: |
21-01-2021, 01:08 PM | #5 | |||
Yeah Damo I think the 100 series & GU Patrol are the most recent 4wds where the clusters can be swapped and aren’t stored in the BCM. The Discovery 2 stores the cluster with the BCM but the LR Nanocom scan tool can change either or to the highest or lowest value. I looked into this as in NZ diesels pay $78 tax per 1000km. I ended up buying a Citroen C5 diesel and unplugging one of the rear ABS sensors, which is used as the VSS. Only downside is I lose cruise control. Last edited by GasoLane; 21-01-2021 at 02:12 PM. Reason: As requested |
2 users like this post: |
21-01-2021, 01:13 PM | #6 | ||
Back in the days of Cable driven Speedos, Unscrew the cable off the Trans & hook up an Electric Drill (from foggy memory you needed a Reversible Drill??) lock the Trigger & into It..
21-01-2021, 01:54 PM | #7 | |||
and would also wind it back when ever in reverse wouldnt work with the way the meck worked in my XY falcon so be older than 70 cable type speedo's was also in the movie fairis bulers day orr where they had been joy riding in his old mans vintage chev and were trying to wind the clock back whilst running in reverse on stands and when they realise it wasnt winding back and he slaped the car in disapoint disloging it from the axle stands , sending it sailing backwards out the back of the building down the hill driverless
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
21-01-2021, 02:47 PM | #8 | |||
It was common for owners of classic Ferraris to disconnect the speedometer actually. |
4 users like this post: |
21-01-2021, 02:50 PM | #9 | |||
21-01-2021, 04:30 PM | #10 | ||
Cabover nut
Best way to hire one of those servo Rent-A-Ute's.
21-01-2021, 08:26 PM | #11 | ||
A friend of mine went to the auctions and bought a v8 panel van. He was very excited as it only had 160kms on the clock. He brought it round as the electric windows weren't working and drivers side was down from when he bought it, easy fixed.
I put the window up to see an oil change sticker saying "next oil change at 320,000". He cryed |
21-01-2021, 09:00 PM | #12 | ||
Frankenford pilot
Low K’s on the clock means nothing.
Look for the obvious signs, ware and tare on the seat, footwell mat, steering wheel, seat belt. It’s not hard to see what’s been tampered with. I recently brought a 18 year old tow pig that showed 117K’s on it. The condition reflects the klm’s. As everyone knows, if it’s to good to be true it usually is, run away.
Cheers Bretto 73 XB GT Last of the Big Ports |
5 users like this post: |
22-01-2021, 10:09 AM | #13 | ||
Cabover nut
Well most of us here.
6 users like this post: |
22-01-2021, 11:03 AM | #14 | ||
22-01-2021, 02:47 PM | #15 | ||
Thailand Specials
Many many moons ago there was an instrumentation side to my employer, they used to do repairs/reconditioning.
Victoria Police used to visit on the regular to check paperwork that no dodgies were going on for odometers, it seems that it was taken more seriously long ago. |
22-01-2021, 02:53 PM | #16 | |||
22-01-2021, 03:33 PM | #17 | ||
lots of people used to do that, you just needed to learn what RPM equated to 100kph etc
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
22-01-2021, 05:43 PM | #18 | ||
Common issue with early commodores, was easy enough to flick the first number around making a 180,000km car an 80,000kms car
I'm little skeptical with low km cars, any odo reading should be supported with the condition of the car, service history and other documentation I worked with a guy who had a VT GTS and the speedo stopped working at very low kms, he had her as a daily driver for 3 years and did abit of a skid in reverse one day, speedo started working again so he decided to sell her on lol |
25-01-2021, 01:56 AM | #19 | ||
Depends on where the car has been used, and what for. Most utes on the mines have extremely low k's. On some sites the u/g Utes are locked info low range.
But the dirt, mud, salt, and water kills them. They're a decent cheap buy when we're finished with them. Labour onsite is hugely expensive, so a Ute can become uneconomical to repair for us, but still be a Good buy for someone who's handy. But gees they are rough. I would imagine the engines are still good, but the bodies are cruddy and the running gear is usually cactus. |
25-01-2021, 01:59 AM | #20 | ||
25-01-2021, 03:15 AM | #21 | ||
praek tih kl jo kr
Looks can be deceiving when buying a used car, some of the bad ones are tarted up to look good so it can be hard for joe average to tell what has been thrashed to within a inch of its life and what is genuine.
My son has a 09 BMW 328i with over 350,000 on the clock, the car looks and drives mint, even the paint is unmarked, you would swear it was a sub 100,000k car the way it drives, previous owner looked after it like crazy, on the other hand my 2010 4x4 Fuso Canter has 55,000ks on it, fortunately mechanically its great, but at the moment it looks like its been driven to the moon and it got bogged there (ex mine vehicle) looks more like a 550,000k truck with the red mud dyed interior, the chassis is so bad I am 1/4 the way into doing a chassis swap. |
25-01-2021, 07:02 AM | #22 | ||
Thailand Specials
25-01-2021, 10:39 PM | #23 | |||
Ford G6ET FG MkII
But the dirt, mud, salt, and water kills them. They're a decent cheap buy when we're finished with them. Labour onsite is hugely expensive, so a Ute can become uneconomical to repair for us, but still be a Good buy for someone who's handy. But gees they are rough. I would imagine the engines are still good, but the bodies are cruddy and the running gear is usually cactus against the law to change the odometer, immoral/inhumane act for the buyer, desperate/idiocy to say the least. |
26-01-2021, 02:34 PM | #24 | ||
Anyone got their AU or BA up to a million?
Does it display 1 million? |
26-01-2021, 02:42 PM | #25 | ||
26-01-2021, 02:57 PM | #26 | ||
In NSW not illegal.
Never heard of a ping when an e-check station has put through lower mileage than year before. I’ve deliberately misread when putting an own rego through with my part-time colleague, just to see if it was followed up. Correct odometer function is not mandated in NSW, speedometer is. |
26-01-2021, 03:27 PM | #27 | |||
Ford G6ET FG MkII
NSW https://www.commerce.wa.gov.au/annou...030%2040%2054. https://www.choice.com.au/transport/...ampering-fraud https://www.racq.com.au/cars-and-dri...odometer-fraud |
26-01-2021, 03:34 PM | #28 | |||
Cabover nut
26-01-2021, 03:37 PM | #29 | ||
Cabover nut
Can't wait to buy a new Yaris, wonder how many cubic feet of stone I can shove in it. As you say we all look at cars objectively.
26-01-2021, 03:42 PM | #30 | ||
