Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Technical Area
Old 20-04-2023, 09:50 PM   #31
mad2
Regular...with metamusal
Default Re: ICC not working
Originally Posted by Ba ford View Post
I was told by auto electrician check fuse under steering wheel on right hand side think it was icc /ign by memory yes can start car have wipers and indicators just nothing with icc unit
the fuse your referring to is listed in the owners manual as fuse 6 - so looking at the dash fuseboard it is the 6th fuse from the left on the lower line of small fuses. the one i referred to is fuse 28 - the 3rd from the right on the top line of small fuses.
Old 07-06-2023, 01:49 PM   #32
UnicornUnihorn
I'm so glad this exists, Because now I'm having this damn issue.
However I'm using the Areopro facia with double din unit and every single fuse is completely fine. Tested a few pins in the main plug for the unit and power is there.
I also plugged the old original ICC which worked in and nothing.
I've never been so confused in my life. Especially that it was working the day before, then started the car next morning and absolutely nothing on the ICC working. Absolute electrical nightmare.
This is such a painful issue.
UnicornUnihorn is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 06:14 PM   #33
raised by monkeys
raised by monkeys's Avatar
My ICC currently goes black. Have audio, screen only turns on as car is turned over or pwr button pressed or changing volume. Havent checked AC controls.
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2023, 07:58 PM   #34
Mont5.0
Mont5.0's Avatar
press and hold volume control knob.
should switch back.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 12-07-2023, 10:22 AM   #35
raised by monkeys
should switch back.
Thanks mate, ill give it a whirl
cheers
Shaun
Current
Previous
Old 12-07-2023, 03:38 PM   #36
raised by monkeys
should switch back.
Worked. Thanks. What happened though?
cheers
Shaun
Current
Previous
Old 12-07-2023, 03:43 PM   #37
foxtrot3
foxtrot3's Avatar
Hi. Holding down the power button for more than 5 seconds turns on/off the screensaver function. It gives you better night vision when the lights are off when you are at the drive-in. Cheers MD
HI
I'M MICHAEL
Old 12-07-2023, 03:44 PM   #38
Its a feature. I do use it if for example doing a long trip at night on un lit roads. So to turn this feature on/off you hold the power button for a few seconds. Every time you make an input the screen will turn on for 5 or so seconds then back off again. So your icc is not faulty, its just a feature.
Old 12-07-2023, 09:56 PM   #39
mad2
yep & it's good to know. hers does it as well as mine - does it on all colour screens but no idea re mono DZ screen [dual zone] or mono screen SZ [single zone].
cheers
