08-01-2009, 09:51 PM | #1 | ||
[ON DUBS]
the electric seat in my lane has stopped working, i press the switch it does nothing.
what should i check? it's gotta be a fuse or something
BA MK2 XR6T |
09-01-2009, 09:15 PM | #2 | ||
[ON DUBS]
has anyone got a gregorys for fairlane or fairmont ghia that could check for me please?
BA MK2 XR6T |
09-01-2009, 09:34 PM | #3 | ||
6 way or 10 way adjustable? In any event there are fuses and a circuit breaker in the fuse box. The ciecuit breaker can be reser by pushing a paper clip end into the hole on the base.
regards Blue |
09-01-2009, 09:45 PM | #4 | ||
All Bran = Regular Member
Also, check the connectors under the seat.
10-01-2009, 01:49 PM | #5 | ||
Irregular member
According to the manual, it's fuse (circuit breaker) #22 which is the top, second from the right in the dash fuse box. This also does the windows and sunroof so I doubt it's that if the windows are working?
#23 which is to its right does the memory seat function.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
10-01-2009, 03:37 PM | #6 | ||
[ON DUBS]
6 way adjustable seat.
connectors under the seat are fine. I had some problems with the power window circuit breaker http://www.fordforums.com.au/showthread.php?t=11244009 the seat stopped working at the same time, the windows are working now and the buzzing hasn't happened again but the seat remains inactive.
BA MK2 XR6T |
11-01-2009, 06:48 PM | #7 | ||
[ON DUBS]
after removing the p/w circuit breaker and putting it back in the seat functions came back so the problem is still relating to the p/w
BA MK2 XR6T |
15-01-2009, 11:42 AM | #8 | ||
[ON DUBS]
this morning when i plugged in the p/w circuit breaker the relay below it started buzzing
and smoke started pouring out of the power plug for the seat. great start to the morning, hopefully the problem is the seat and i can just leave it unplugged
BA MK2 XR6T |
15-01-2009, 02:58 PM | #9 | ||
Irregular member
Doesn't sound too good, hope you can get it sorted out. Let us know of the outcome.
Have you done some power tests or something to make sure it's getting the right power, so you can isolate it to the motor?
03-02-2020, 04:55 PM | #11 | ||
Next upgraded Mk1 Leopard
Can you take it out and manually wind it down?
03-02-2020, 05:39 PM | #12 | ||
Uncle ken,manually wind it down? I’ve got the seat out and was considering putting power to the motor to see if I can move it.The seats are bolted through a pivoting hinge so maybe just fold them down.and reinstall.
03-02-2020, 09:30 PM | #13 | ||
Anyone know what the spare white plug is for under my Ba GT seat? Seats are not in a GT but they are in a BA.Tried to manually wind the seats down but they are stuck solid:( Seatbelt warning works but no adjustment so Next I’ll try the fuse.
