Old 20-12-2023, 02:35 PM   #1
woodiebro
Default fuel filler 2010 fiesta
We have a 2010 diesel fiesta and I just went to fill it up and the fuel hose nozzel wouldn't enter.It would appear that the small metal flap at the entrance wouldn't open. Is this a common issue and what is the fix.And yes I did use the correct pump. Thanks
woodiebro is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2023, 03:45 PM   #2
GTLEGEND
Default Re: fuel filler 2010 fiesta
2010 is a change over year between WS & WT Fiesta, which one do you have as they are different and also what engine capacity diesel is it?
Old 20-12-2023, 04:45 PM   #3
woodiebro
Thanks GT, The car is a 1.6 WT
Old 20-12-2023, 04:55 PM   #4
GTLEGEND
You will need to source the fuel filler pipe part number DK5142210G, unfortunately obsolete from Ford.
Old 23-12-2023, 09:22 AM   #5
woodiebro
Thanks GT, looks like I will have to chase wreckers or after market. Does the flap at the entrance play a part in the system or just to keep debri out. Just looking at what I could use off another vehicle with a screw type cap. The car runs like clockwork at 137k so need to find a solution. Merry Xmas.
Old 23-12-2023, 01:16 PM   #6
GTLEGEND
In the image below that part is called a dust cover, part number DN3242240A (obsolete also), but I am sure it plays apart in the fuel system. If you go to the wreckers you may be able to take off the top cap bit that has the flap in it. If I remember correctly they did come apart. As you can see in the image that is a separate piece but obsolete from Ford.
Old 28-12-2023, 09:33 AM   #7
GTLEGEND
Does this look similar to what you're chasing or completely different?
https://www.ebay.com.au/itm/325945220101
Old 28-12-2023, 11:46 AM   #8
woodiebro
Very similar.
Old 28-12-2023, 11:58 AM   #9
GTLEGEND
Very similar.
That might work and solve your issue.
