Old 02-05-2021, 08:48 PM   #1
ToyotaCorolla
Default Power steering pump leaking
The fluid in the power steering reservoir keeps leaking, I already top it up twice, however I cannot seem to find the cause of the leak.
I already replace the high pressure hose, and check it multiple times, dry! It must be leaking else where :(
https://imgur.com/MvEpi4g.jpg
ToyotaCorolla is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2021, 09:32 PM   #2
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
Default Re: Power steering pump leaking
If leaking on the hose as per pic it's either front seal or the can is leaking. A basic rebuild kit will replace those seals
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2021, 09:42 PM   #3
Metdevil
Check the Power Steering Pressure Switch, mine leaked from there a couple of times. Not too sure what causes it to fail, but mine was leaking through the switch assembly and out the electrical connector.
To get to it, I believe it's a 14mm, find a sacrificial spanner that you can cut short and grind a bit of the thickness off it so that the 'prongs' of the spanner come to a sharp point.
There's not much clearance to get a spanner in there, so it's easier to just cut the spanner short.
There's a diagram here which shows where to find it.
http://fordforums.com.au/wsmpub/augx/Part%203-3.html
Metdevil is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2021, 10:26 PM   #4
The O rings fails as many of the aftermarket ones are fitted with an O ring that is not resistant to power steering fluid and dissolve away. Aftermarket often come with buna or Nitrile rubber O ring gaskets that are not resistant to power steering fluid and dissolve to mush. Polyacrylate 'O' rings are best. Plumbers tape or master pipe sealant won't work either. For this reason it's worth getting the factory O ring even if you use an aftermarket switch. They are easiest to get at by removing the driver's side front wheel with the car on a solid jack stand and getting to it from below. Better still using a ramp or car lift. Trying to do it from within the engine bay alothough and obvious choice is an uphill struggle. The size of spanner needed can vary as the aftermarket and factory ones have a different size hex to the factory one and even different aftermarket ones can be different; in any event don't assume the spanner used to remove the old switch will also fit the replacement switch. Make sure you use the hex fitting to tighten it otherwise the plastic body bit will crack and leak. Also see https://fordforums.com.au/showthread.php?t=11381608 and http://www.fordforums.com.au/showthread.php?t=11224081 etc
Old 02-05-2021, 11:01 PM   #5
Metdevil
Originally Posted by aussiblue View Post
The O rings fails as many of the aftermarket ones are fitted with an O ring that is not resistant to power steering fluid and dissolve away...
On both of mine that went, the O rings were fine. As in that thread you linked, the leak was coming from the connector, not the thread. Wasn't aware that aftermarket O rings were yet another point of failure :(
Also tried coming at it from below before resorting to mutilating a spanner. Getting to it from above was definitely preferable in my case.
On the topic of spanners, I also found that I had one of those Ikea spanners which must've come with a $15 bookshelf or something which was perfect for the job too.
Old 02-05-2021, 11:23 PM   #6
George V
^^ What he said.
Get a rebuild / reseal kit for pump;
The following from ebay has instructions:
https://www.ebay.com.au/itm/37282060...Cclp%3A2334524
Regards,
George V
George V is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2021, 01:43 PM   #7
Yes; now looking at the picture it's time to replace the seal or the pump (the latter is easier and sometimes cheaper if you are paying someone to do it or don't have the required tools and/or skills).
Old 03-05-2021, 07:37 PM   #8
ToyotaCorolla
How much would the mechanic charge to replace the pump?
Is it hard to replace the pump yourself? It's just getting the part from repco, drain the fluid, remove the nuts(mounts the unit to the engine frame) and hose(high and low), put new pump on, reconnect the nuts and hose, put in fluid in?
Having said that, it does look like a tight spot to work on!
cheers
Old 03-05-2021, 10:17 PM   #9
You also have to bleed the power steering system but that's not difficult either.
