Old 13-11-2022, 07:10 PM   #1
Edxr6
Default AU XR8 Series 3, Instrument Cluster
Guys,
Sometimes when I am driving, all the instrument icons light up in the speedometer section, the tacho and speedo needles drop to zero for about 2-3 seconds and the seat belt light (Red) remains on for about 5 seconds. Then everything returns to normal, no issue with performance whilst this is occurring. The car seems absolutely normal, no hiccups or misses with the engine running. Very strange. By the way, my seat belt is secured in the stalk correctly and locked in.
Has anyone experienced the same with their AU XR8 clusters.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2022, 09:57 PM   #2
Edxr6
Default Re: AU XR8 Series 3, Instrument Cluster
Sorry Guys, it’s the odometer section where the icons all come up.
Old 13-11-2022, 09:58 PM   #3
portokatsiki
I've had a similar thing happen on a S2 fairmont I had but it was a 6 cylinder years ago, I just lived with it. Also happened on my current S2 xls ute 6 cylinder also. After I fitted an XR cluster on my ute, hasn't happen again. Does it happen to you more regularly when the wipers are in use?
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2023, 12:18 PM   #4
Edxr6
No, not really when the wipers are operational.
Old 01-01-2023, 12:31 PM   #5
PG2
#neuteredlyfe
PG2's Avatar
It could be a bad earth or loose connection.
Ensure that the plugs are securely plugged into the back of the cluster.
