10-06-2021, 01:17 PM | #1 | ||
Hi Guys, Thanks for having a look at my thread. I removed the Throttle body to clean it opened it right up to give it a good old clean. Refitted it sparkling clean, when I started her up it came up with ESP SYSTEM FAULT and was running rough as a badgers ****. I'm wondering if I've damaged the Thottle Body? any advice would be greatly appreciated. Cheers.
10-06-2021, 10:01 PM | #2 | ||
First check all connections are in the correct place and tight
Scan for codes copy clear then rescan |
11-06-2021, 08:35 AM | #3 | ||
These are electronic (ie not cable operated) ?? If you've opened the throttle body butterfly by hand, then you're likely to cause damage..
11-06-2021, 05:56 PM | #4 | ||
if you are really lucky it may just need to relearn the calibration. plenty of videos on Utube to help you.
