Old 02-07-2010, 10:10 PM   #1
XESP351
XESP351's Avatar
Default XE 4.1 X flow Turbo
Hey guys,
I'm aware you guys mainly work on late-ish model Fords. But i was wondering if you'd be able to help with a 4.1 X flow Turbo conversion. If not let me know.
The XE is stock at the moment, and it's actually a 3.3, and it's dual Fuel. It has factory everything including exhaust, carby etc. I would like to have the engine rebuilt as a 4.1 and set up for straight gas turbo (so low comp, gas heads and cam etc.) but i don't think you do that kind of engine building work, correct me if i'm wrong though. I'm looking at max power of 300 rwkw eventually out of the set-up.
I guess what i'd like help with is mainly the turbo set-up as i'm a V8 man and know FA about Turbos. So type of, and where to source, turbo and associated equipment, exhaust manifold, Gas research set up, plennum etc all for reasonable cost is all things i need advice about, also things like what exhaust set up i will need and also cooling system.
Other than the engine work i get the feeling Blue Power is an all stop shop for the remainder of the set up and i'd like to have a chat about the above and all the costs for you to do the job etc.
I'm not looking to get the job completed until another three months or so but i'd like to start accumulating the parts from now, so it's all good to go when the time comes.
Feel free to PM me or if's easier to speak on the phone or in person let me know and i'll call in.
Thanks. Fady.
XESP351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2010, 01:23 AM   #2
Belial
Clevo Mafia Muscle Man
Belial's Avatar
Pfft,
Chris, just chuck in a JZA80 engine........
This will interesting to see what the BPR guy's can do...
Toy
XB GS 351 Manual Sedan (The "Pig")
Daily
FPV GS Manual Sedan. (1 of 20)
now 360rwhp thanx to Blue Power Racing
"Global warming..." " I'm doing my part!"
Also a member of the Clevo Mafia.
You hit me, we hit you!
Metal Jacket Muscle Car Club
Belial is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2010, 09:22 AM   #3
PSI-54L
PSI-54L's Avatar
Thought about putting an XR6-Turbo motor in?
They handle gas well. and will have a reliable 300rwkw daily.
Cheap and easy to source parts and have work done to.
Food for thought...
Chad.
Supercharged XR8
HSV
CVO Breakout
PSI-54L is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2010, 09:57 AM   #4
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Originally Posted by XESP351
Hey guys,
Thanks. Fady.
Fady,
Thanks for your Enquiry mate. This is a project that is a little different to what we would normally see.
The reality here is actually that the engine side of things is more our specialty, whereas one off fabrication on these older vehicles is not.
Mark Johnson at JPC in thomastown has done several of these cars to great effect, and would be the person to whom I would steer you for such a project. Having had the experience, im sure Mark could steer you in the right direction, from fabrication, product selection down to tuning.
Like I eluded to, this is not something we would take on due to our lack of experience with this setup, which is why we will point you to someone who has a great track record in this conversion.
Good luck with it mate, and if we can be of assistance in the future, please let us know.
Regards
Theo
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 01:23 AM   #5
mickyyyy
Theo is right about JPC as he has done alot of LPG turbo setups and a mate is getting Mark to tune his vl turbo wagon with a big setup, its runs a gas research gear with a Haltech spirit 500 unit for ignition and should be tuned there soon.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 07:16 PM   #6
XESP351
XESP351's Avatar
Food for thought...
Hi, thanks for the suggestion mate. Yes i did thing about XR6T setup, but as i'm a bit old school i'd rather avoid complex computers, ECU's and stuff as much as i can. Plus the way i'd like to have the set up, the car doesn't require an engineer's certificate (according to VICROADS) and the factory engine will remain so no need to change engine numbers etc. Obviuosly all this would be different with an XR6T motor. Thanks again.
Old 04-07-2010, 07:22 PM   #7
XESP351
XESP351's Avatar
Originally Posted by Theo@BluePower
Fady,
Regards
Theo
Not a prob at all Theo, thanks for being honest mate. I'll get in touch with Mark at JPC and let him know you referred me. Thanks again mate, and i'm sure we'll talk soon either way.
Fady.
Old 24-07-2010, 09:59 PM   #8
foxtrot3
foxtrot3's Avatar
Hi Try getting in touch with Dave at swift automotive in dandenong http://www.swiftauto.com.au/Home.aspx . He's had a few lpg fueled turbo falcons from XE on. Cheers MD
HI
I'M MICHAEL
