Old 21-12-2008, 10:41 AM   #1
phibza_XR6
drive it like u stole it
phibza_XR6's Avatar
Default cable clutch to hydraulic setup
hey guys, was wondering if anyone has converted the cable clutch setups in the ford i6 to hydraulic. Have snapped another cable and really want to convert it to a hydraulic type. any help would be great thanks
www.aufalcon.com/phibza
phibza_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2008, 11:41 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Now thats a fair challange from the pedal box to the master cylnder to the slave to the clutch fork. could be done but wont be cheap. you could try a race enginering shop for some advice as to parts. they advertise in AutoAction.. good luck with it
Originally Posted by Riksta
Old 21-12-2008, 11:54 AM   #3
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Mal Wood Automotive have an AU hydraulic pedal kit utilizing an under dash master cylinder and a remote reservior (B-series). I have it on my T1 and it works great. I am sure that when they did the development for it at the end of last year they used an AU 6 cylinder ute as the mule.
Give them a call and speak to Mal or Ben
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2008, 02:15 PM   #4
5LGhiaWgn
5LGhiaWgn's Avatar
Daniel
Priced one up when i was doing the 6 speed conversion they are about $800 od back in march this year from Malwood
5LGhiaWgn is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2008, 04:27 PM   #5
Sox
RIP...
Sox's Avatar
I've owned manual Falcons which used the same setup as an AU since 1993. I must have owned at least 10 different manual coons, which now included 3 AU's.
I have not once broken a clutch cable, however there have been other problems.
There are other issues which need sorting before I'd even consider a hydraulic conversion.
Make sure the angle of the clutch pedal is correct, as it's common for them to bend and eventually break off. If it is, it will need welding.
Check the alignment of the tube which exits the firewall where the adjustment nut is located. These also crack, and need welding.
Make sure the cable is routed properly and not kinked.
The fingers at the clutch fork also open up, I have had to tie-wire it with some of the heavier duty clutches.
Make sure everything is lubricated well.
If you follow the above, your clutch cable should never break and it will be easy and smooth to operate.
Oval Everywhere...
Old 06-12-2009, 04:12 PM   #6
OED666
OED666's Avatar
I know I am thread mining, but you can convert from cable to hydraulic clutch setup. The cost is around $1490, for everything required. The pedal assembly is around $790, then $390 for a hydraulic bearing, $170 for a braided line, and the rest is incidentials required for the setup (exchange front bearing retainer... and a few other things)
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
