Old 09-03-2011, 09:14 PM   #1
prozak
problem king
Default KF tx3 turbo cutting out
Hey all, Ford Laser TX3 Turbo FWD KF 1990....
I turn a corner, and the car wont rev? it jerks
I flat foot in 2nd gear on a straight, and the car revs up but cuts out as the revs are increasing
im running 12psi, my g-reddy boost controller screen shows the boost is dropping when the car jerks...
im curious it may be fuel pressure problems ( due to me turning it cuts out, used to be only when under 1/4 a tank, now it does it at 1/2 tank, and the car idles like crap ) , whats the pressure meant to be? ill wack a guage on it this weekend so see if the pressure drops as i turn a corner to source the problem & check it @ idle.....
cheers, any other thoughts will be appreciated...
prozak is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2011, 01:59 AM   #2
kcaillin666
New Ford Owner
Default Re: KF tx3 turbo cutting out
Does the Boost cut buzzer sound??
Is it a Standard Turbo? or have you done the VF10 hybrid?
14psi is maximum you can run on a std ecu, so it may just be Overboosting and cutting out? more info required
kcaillin666 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2011, 05:55 PM   #3
prozak
problem king
put a fuel guage on it, drove around the corner dropped to 9psi, i put a new fuel pump, she runs better than ever only $110 cheering !
Old 18-04-2011, 05:37 PM   #4
kcaillin666
New Ford Owner
nice work, Now look for a cheap vf10 to hybrid it!
