Old 28-01-2016, 05:01 PM   #1
Mesa
Default Fuel Pump o rings
Just had the mechanic replace the daughters fuel pump on her 1999 Cougar but now its spraying fuel everywhere. The o rings are shot. He can't track down any. Does anyone know where to get an o ring kit for these??
Thanks.
Mesa is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2016, 08:35 AM   #2
REDDYZ
REDDYZ's Avatar
Default Re: Fuel Pump o rings
www.rockauto.com has fuel pump gaskets (O ring). If you're after the O rings of the hoses that goes into the pump ebay might be the best option or there will be heaps of generic O ring sets to match the one needed. Sometimes Ford spares can help as those parts might still be in use on other cars.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2016, 08:48 AM   #3
Mesa
Thanks REDDYZ. Much appreciated!!!
Old 03-03-2016, 12:49 AM   #4
GTLEGEND
How did ypou go with the O ring? Are you referring to part 11 of the attached picture? If so there are two different o rings for Cougar. 1 for 1/6/1999 to 31/07/1999 Part number XS8Z 9276 AB. 2 from 1/8/1999 on part number XS2Z 9276 AA. If you let me know exactly which one you need, I can do a bit of a search to see if anybody has any..
Cougar Fuel.pdf
Cheers.
PS sorry for the late post and hope you have fixed your issue, just saw it and willing to help if required.
Old 04-03-2016, 12:04 AM   #5
Mesa
Thanks GTLEGEND.
The workshop where she had it ended up going through gaskets and o rings at a couple of local parts place and found one. I'm surprised the new pump didn't come with them.
It's running far better but still hesitates a little bit. She's replacing the plugs next.
Great little car!!
Old 17-03-2016, 03:43 PM   #6
thearrow
You were so lucky finding the correct replacement as I had no end of trouble. FYI Ford in the USA used at least 6 different types of fuel pumps in Cougars as they continually had problems. In the end 2001 they completely changed the fuel system.
When mine went my mechanic had to cobble together the old one with the new one I bought from the UK to make it work. I was a HUGE problem.
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
