13-04-2016, 12:22 PM | #1 | ||
Iv'e also posted this in the Ranger section but may get a bigger response here.I'm looking at a 2007 3litre engine with 240000ks runs and drives well.Could I reasonably expect 4-500000 from it or am I being optimistic.I seen a few advertised for $20000+ This is a lot less than that so is it worth buying with a $5000 fix up reserve
13-04-2016, 01:59 PM | #2 | ||
Sounds very similar to all other trade -in, used car posts to me.
It's for sale because the previous owner made a judgement that from now on the expenses would start to accumulate. Keeping that in mind, everything is for sale at a price but with vehicles it's much more important to recognise that EVERY BIT of the Ranger is 9 years old and ALL moving parts have done 240,000 klms. Very cheap offer would be my advice. My son just bought a used Ranger which had been running around the Western Qld gas fields, seems OK so far. |
13-04-2016, 02:13 PM | #3 | ||
I would allow a $10,000 fix-up reserve.
Dr Terry |
13-04-2016, 03:08 PM | #4 | |||
13-04-2016, 03:11 PM | #5 | ||
Biggest factor with common rail motors is how lucky you get with fuel contamination / injector / high pressure pump issues. Easy to kill a motor and big $$ to fix.
PJ/PK rangers are prone to head gasket / EGR cracking issues.
2015 Toyota Landcruiser 79 V8 SC |
13-04-2016, 03:17 PM | #6 | ||
It is a difficult question to answer. No two cars are the same. You will 500k out of but it is a guess as to how much it will cost you. Good thing is that ute is relatively simple mechanically compared to your average passenger car.
13-04-2016, 03:30 PM | #7 | ||
bitch lasagne
What's the asking price Tassie?
13-04-2016, 03:43 PM | #8 | ||
13-04-2016, 04:06 PM | #9 | |||
The problem with modern cars at high milage is that the engine will outlast all of the bits attached to it. Those bits can get expensive. Dr Terry |
13-04-2016, 04:09 PM | #10 | ||
bitch lasagne
I wouldn't, for the reasons stated by the others.
13-04-2016, 05:09 PM | #11 | ||
The things i would be worried about would be things like , fuel system , injector pumps, neglected cooling systems , these items could easily run you thousands of dollars if things go bad.
13-04-2016, 08:15 PM | #12 | ||
The expression of spending nickels and dimes on it may drive you insane. Couple hundred here. A little more there, odd electrical fault, replace some worn bushes, and you'll be so deep before you really catch yourself. If you buy it, set a rock solid budget and don't go blowing through it.
Now- AMG W211 E55 Then - BFII F6 Coming - 84 XE S-pac |
13-04-2016, 08:36 PM | #13 | ||
I service bloke at Mitsubishi was telling me all these modern diesels really only do well for about 300,000. Said they are not like the old patrol 4.2 turbo diesels where you would expect the same problems at more like 600000+ km!
They are made to throw in the towel i believe at a specified life. Just like new cars (exept falcons). |
13-04-2016, 08:48 PM | #14 | ||
The Vengeful One
well that's good to no, means my Patrols only half worn in lol
13-04-2016, 09:42 PM | #15 | ||
Have a good look at the EGR system and the heat exchanger tied to it. Is known to fail and cause premature engine failure.
13-04-2016, 10:08 PM | #17 | ||
Probably a bit like expecting a 3.2 Ranger lasting any wherspe as long as a Cruiser with a bigger engine but only a couple more KW and allegedly less torques
13-04-2016, 10:42 PM | #18 | ||
Revs/kilometer has to mean something. Engines that did 5-600,000 klms were normally slower revving engines.
The 4.2 NA 100 series I had [ an absolute dog of a thing to drive ] was doing 2,000 rpm at 100kph. What rpm does the Ranger engine do at 100kph? |
13-04-2016, 11:06 PM | #19 | ||
How much is it?
13-04-2016, 11:10 PM | #20 | ||
A 2wd manual 2.2l diesel ranger sits at 2000 at 100kmh. I drive one for work. Its a 2013 px though
14-04-2016, 02:25 AM | #21 | ||
Two Wheels Good
All late model diesels are more highly stressed than traditional diesels. But 240k isn't terrible if the servicing has been thorough - oil change every 10k minimum.
Remember you only hear the horror stories online - for every engine that's failed at 200k there's dozens that are well on their way to double that. My GQ TD42 has 428k on the clock and as someone said earlier will go to 600k easily - but those days are gone thanks to emission requirements.
2004 SX TX RWD Territory 2010 Mazda 3 1994 GQ DX TD42 Patrol 1969 Kombi |
14-04-2016, 07:42 AM | #22 | ||
Key is regular maintenance , yes rangers and bt50 have their problems. But if properly maintained your ute will go 500k , I have a bt50 08 model doesn't miss a beat.
14-04-2016, 08:30 AM | #23 | |||
The only modern ones that may last are the v8 diesel landcruisers. AND the latest group are getting smaller and more highly strung! The triton is now a tiny 2.2, was already quite highly strung as a 2.5, the VW is just a 2.0 (How long are they going to last! Any reports?) Makes the Dmax 3.0 with a little less power than the others seem like it may be the one to go for for longevity. |
14-04-2016, 08:37 AM | #24 | |||
14-04-2016, 08:39 AM | #25 | |||
If your doing 25-30,000k per year, then your talking 7-10years to reach 500,000k's. Also why not spend the extra you are planning to put aside for future repairs, and by a lower K example.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC Last edited by Mont5.0; 14-04-2016 at 08:44 AM. |
14-04-2016, 09:39 AM | #26 | |||
New ,smaller engines make more power and are more efficient.People used to say turbocharged engines won't last. Something like an NA HZ engine will last forever but what are they like to drive ? Triton is 2.4 with 133kW/430Nm - compression ratio only 15.5 :1 . Isuzu 3l 4JJ is 17.3 compression ratio 130kW/380Nm. It is all relative as in Europe they consider 2.4l engine big. They get huge milages out of 1.9l VAG or other similar small diesels. Last edited by SumoDog68; 14-04-2016 at 09:44 AM. |
14-04-2016, 10:23 AM | #27 | ||
It is actually Bt50 freestyle with a flattray 4x4 Dx with alloys electrics etc.The starting price was $14000 but I think it is a bit negotiable.I could maybe spend the extra $5-6000 on something newer but still be around $20000 odd and still have 150000 km.
14-04-2016, 10:37 AM | #28 | ||
IMO 150k on a well maintained diesel engine in nothing.
14-04-2016, 10:38 AM | #29 | ||
bitch lasagne
I'm about to take delivery of a diesel X-Trail and have placed an order for the Water Watch kit. The reason: warranty won't cover contaminated fuel and insurance policies vary in their coverage of such failures.
14-04-2016, 11:29 AM | #30 | ||
Wirlankarra yanama
Check for damaged/repaired panels/chassis
Check that it wasn't a repairable write off Check for rust Check that things work Check service records Check engine compression Check fuel injector values are within specification Check fuel filter for contamination Get oil analysis Cross fingers hope for the best, it is nearly 10 years old, it is what it is. |
