Old 11-12-2017, 09:23 PM   #1
GrannyLeeBoo
Default 91 KH Laser no spark!!
Hi guys. Have a kh laser that died on the highway with no warning. Checked for spark and got nothing. Replaced dizzy. Nothing. Replaced coil. Nothing. Replaced leads. Nothing. Used a light tester on coil and it has power on one plug. I am stumped. Any ideas???
GrannyLeeBoo is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2017, 09:33 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: 91 KH Laser no spark!!
Assuming you've replaced the HT lead (coil to distributor) then the next thing is to check the main engine fuse. The distributor module (the black thing inside the distributor) can fail as well but if you replaced the distributor that's unlikely.
Russ
Observatio Facta Rotae
Old 12-12-2017, 12:44 PM   #3
GrannyLeeBoo
I did replace ht lead. I checked main fuse and it looks ok. Would it still crank if main fuse is blown? It still cranks just doesnt fire
Old 12-12-2017, 02:27 PM   #4
Beastie
The Terrain Tamer
Beastie's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Catering services for a bunch of layabouts and for being an all-round good guy whose sense of community goes above and beyond.
Pull a spark plug out, reconnect the ignition lead and hold it near the engine while someone cranks the engine. If there is spark, you should be able to see it 'earth' to the engine.
If there is spark, then it sounds like a fuel issue.
Current Ride : A Ford owned D3...
Beastie is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2017, 02:35 PM   #5
GrannyLeeBoo
It has no spark. Even after replacing everything
Old 12-12-2017, 03:15 PM   #6
Beastie
The Terrain Tamer
Beastie's Avatar
The next thing you could check then is the wiring loom from the dizzy. Are there any broken wires or plugs?
Old 12-12-2017, 03:36 PM   #7
GrannyLeeBoo
From dizzy to coil? No broken wires. The connections all look fine aswell. I will get contact cleaner and spray them just to be safe
Old 12-12-2017, 04:11 PM   #8
GTLEGEND
I had a similar issue on my KH and it was the distributor module inside the dizzy. Did you replace the dizzy with a new or second hand unit and are you sure the dizzy you replaced it with does not have the same problem? Are you getting power to the dizzy and is it earthed ok?
Old 25-01-2018, 02:00 AM   #9
Mechan1k
Mechan1k's Avatar
Had the same issue with my Mum's KF GHIA .... it intermittently had issues starting ... and then just didn't start at all ... the Dizzy module back then was hard to get ... I had to get one from the wrecker at the time.
Thread Tools
Display Modes
