Old 15-11-2017, 12:58 PM   #1
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Default Ka....what coolant lines run from/to and whats should be there???
I have a little Ka i use to get to work and back as i do a lengthy commute. Great cheap to run little car and don't really care about others opinions of it, makes me laugh.
Anyway, driving into the airport the other day steam, overheating blah blah, thought this is the END. Nah, things might be slow and dodgy but the 1.3 is bulletproof (not like its stressed is it??)
I found a loose coolant line pumping out coolant when i threw some in. which came from the passenger side but so far haven't been able to suss much more, visibility sucks at the rear of the engine. Think it may be the line heading to the heat exchange for the heater, maybe. BUT....it still has it's clamp on and stops way short and i can't see where is actually goes. The heat exchanger itself has another line on it which is intact heading back towards the passenger side also, but the other connection isn't connected. I'm tempted to think someone has bypassed the thing and what i'm seeing is either something missing or some jiggery buggery bypass i can't make sense of.
I'll take a look later, but i was wondering if anyone with access would have a diag/pic of where the coolant lines run on the 1.3 Endura-E? If there's jiggery buggery i'd rather reverse that and get the heater back up and running, or at least know enough to get the cooling system temporarily intact again to get her mobile
Any help appreciated ;) I can find diags for PS and AC systems but not the coolant flow.
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1
A stereo that happens to have a XR5 wrapped around it
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2017, 08:49 PM   #2
stock1991
Limited supply
stock1991's Avatar
Default Re: Ka....what coolant lines run from/to and whats should be there???
LOL
stock1991 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2017, 07:06 AM   #3
russellw
russellw's Avatar
We have the workshop manual for the AU spec TB kA in the Tech Portal so that might be a good starting point.
Russ
Old 16-11-2017, 12:36 PM   #4
PepeLePew
PepeLePew's Avatar
Yeah thanks Russ I did flick through that and it'll be great to have, i'm sure i'll use it again Just didn't have diags of the piping, but got some guidance off EBay visually. I've found the issue anyway, plastic degraded on the heater valve and the tang for the hose snapped off, being on quick release fitting at the other end it just flopped down the bottom of the firewall giving a misleading picture of where it'd come from. New valve on order for stuff all, 1/2 hour job an she'll be back on the road. And the heater will be working
