24-04-2009, 03:36 PM | #1 | ||
i am having a problem with a 2006 ford focus
airbag warning light is always on and seat belt light car has been checked on scanner no comunications with the air bag controller ecu passes everything but airbag control unit seems like no power to unit or bad connector have put in new airbag controller still same fault. |
25-04-2009, 01:10 AM | #2 | ||
yum
How long has this probem been there for, did you buy the car new?
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
25-04-2009, 11:48 AM | #3 | ||
did you put in a new SAS unit (airbag controller) yourself or ford did it? When new SAS module's are fitted to car's they can't just be plugged in, they have to get programmed
2009 FG turbo ute 1983 Toyota sprinter- quick/fun car with a Nissan heart 2010 CRF250- when I want to get dirty |
28-04-2009, 07:51 AM | #4 | ||
yes ford did put the new one in the fault is that the ecu can not comunicate with the airbag controller no comms everything else test ok.ford said check wiring or fuse
thanks david |
