06-07-2011, 05:05 PM | #1 | ||
hey guys ive got an oil leak at the front of the engine. there is an electrical connector that plugs right in the middle of the engine up the front what is this? looks like it might be coming from there. any other ideas what might leak there as its really hard to see with all the pulleys in the way.
cheers guys au 2 falcon ute |
06-07-2011, 06:07 PM | #3 | ||
thanks i just degreased it and let it run for bout 10 mins and it seems to be coming from the bottom bolt that holds the power steering pump to the block. think ill have to pull it out and put some sealant on the bolt.
06-07-2011, 06:26 PM | #4 | |||
AU DIE HARD
More likely it's coming from the timing chain tensioner ,which is in behind the power steer pump bracket , fairly common that they work loose I willl see if I can find a thread on them
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
06-07-2011, 06:33 PM | #5 | ||
AU DIE HARD
there"s a picky of the culprit you can tighten it with out removing it if you get all the brackets out of the road
http://www.fordforums.com.au/showpos...39&postcount=8 |
06-07-2011, 06:54 PM | #6 | ||
thanks mate will have a look tomora.
06-07-2011, 07:59 PM | #7 | ||
I had this too, was just loose, easy fix..
11-07-2011, 04:57 PM | #8 | ||
Also had this recently on a S1 Futura. Thanks to the link posted, showed me what needed to be done to fix it. Bit of a pain to get to but fixed it in the end.
11-07-2011, 06:45 PM | #9 | ||
Had the same .. except mine didn't tighten ... so had it replaced.
No more leak (god it leaked though)
11-07-2011, 07:09 PM | #10 | |||
17-07-2011, 07:19 PM | #11 | ||
Next upgraded Mk1 Leopard
I did mine today, what a stupid place to put it. Took lots of pic's will post a 'how to' later.
UK
17-07-2011, 09:29 PM | #12 | ||
that would be great
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
17-07-2011, 11:21 PM | #13 | |||
AU DIE HARD
UK fairly sure there is a how to already there someware thats how I fixed th SR
I
17-07-2011, 11:29 PM | #14 | ||
I will look more deeper into this, as it may be the cause of the presence of oil on the front of my engine. Cheers for the coincidence
18-07-2011, 03:44 PM | #15 | |||
23-07-2011, 06:45 PM | #16 | ||
Whoosha I wrote this up anyway UK
Like many others I had a small leak around the fan belt coming from the Timing cover seal. So another How to: fix trimming chain plug leak. HOWEVER....before you start... It should be possible to just tighten the Timing cover seal without taking anything off. Access would be very ‘blind’ but if you have a socket set, try accessing from this angle. Of course you can’t check the seal, only tighten the bolt. So to do it the long way... Tools required, socket set 10-20, ring and open end spanners 10-20, extension bar, crow bar, gasket goo, degrease, string, an old towel, 1 Phillip's head and straight screw driver 1. Park the car wear you can degrease as you work. Remove the fan belt cover if you have one 2. Remove air intake, put the 2 screws ‘somewhere safe’ 3. With the fan belt now exposed, use the crow bar to release pressure off the belt ready to slide it of the Power steering pulley. N.B. I used a long piece of wood, this worked to get the belt of but the wood had snapped by the time I went to put it back on. The crow bar was much safer/easier. With the tension off, use the screw driver to slide the belt of the pulleys. 4. Tie the belt to the pipes over the radiator. This will save a bit of work re threading later. 5. With the fan belt off, time to remove the Power Steering reservoir. 6. There are several bolts and 1 nut to remove to take of the Power Steering reservoir. Remove the single nut. 7. Now remove the 3 blots at the front of the Power Steering pump. You will need to access 2 bots through the pulley wheel. and 2 bolts (1 high 1 low) You can now gently lift of the Power Steering pump. I placed mine just back near the coolant reservoir. With the Power Steering pump off you can access the holding bracket. 8. Next remove the 4 blots located here. I used a ring spanner (they weren’t to tight) and a tube. (As you can see the pump is still on. I have changed the order to make it easier to do) and and 9. Next, remove the 3 blots located at the front. The fan belt will get in the way, just push it down. There is still 1 bolt holding the bracket to the engine block. Undo and remove the bracket. It will need a clean with degrease. 10. You can now see the Timing cover seal blot. Mine had oil and dirt all around. Use an old towel to clean up the mess before unbolting. Leave the towel there as some oil will leak out when you remove the bolt. Also have the gasket goo handy ready for the next step. 11. Get a ring spanner and undo the Timing cover seal blot. (I took this pic before I put the towel down, have the towel here to stop oil leaking) 12. Remove the Timing cover seal and clean it and the engine block. Check the ring washer. Mine looked OK so I simply put some gasket goo on the seal and screwed it back in. I cleaned the area again with the old towel to remove any oil that had leaked out. (image from Whoosha) 13. Apply a bead of gasket goo and screw it back in half way. Clean the shaft of oil and check the gasket goo. If OK tighten up. To make a tight fit and seal I used a spark plug tube for extra leverage when tightening the seal back on. 14. Clean up again if you have to run your finger around the area to smooth out excess gasket goo. Now is a good time to spray on some degrease in the area, let it penetrate (and the gasket goo to dry a bit) and have a cup of tea, smoke, beer etc. When the gasket goo feels OK wash of the degrease before reassembling. 15. The reassembling is just the reverse of the above, but take the opportunity to give everything a clean. Hopefully all the bolts you put somewhere same are still there. 16. Loosely put the Power steering pump back on as it will help putting on the fan belt. Putting the fan belt back on was a pain until I used the crow bar. Wedge it in here as Whoosha shows here. 17. With the Power steering pump and fan belt back on replace the air intake and fan belt cover and you are done. Fire up the car and check everything is OK, with any luck no more leaks. As far as I know this is the same for Series I, II and III Au's. Allow say half a day to do it, better done with good light. Its a greasy job so have hand cleaner close by. Good luck I think it was worth the effort. UK
23-07-2011, 07:35 PM | #17 | ||
love your work ty
23-07-2011, 08:35 PM | #18 | |||
AU DIE HARD
Nice work as always UK
23-07-2011, 08:50 PM | #19 | |||
http://www.fordforums.com.au/showpos...39&postcount=8 only cleaned it, then slide it back in. I did not adjust anything. Is that OK? The car has been running for week and no problems re leaks or engine timmming. UK
24-07-2011, 11:16 AM | #20 | |||
AU DIE HARD
If you only took the plug out ,cleaned and resealed it back in thats fine . the actual tensioner adjuster part screws in and out with Allen keys and has settings ext. the one I did fell out with the plug but was a easy fix. still haven found the how to I used at the time, it may have gone into cyber space when we had the Melt down a while back .. I will paste the link up in the How to section for you when I get 10 min. to spare, and you can forward my 5% cut for the hand shot to my account
24-07-2011, 11:38 AM | #21 | |||
I will change the 'how to' top reflect this. I think it would be OK if the tensioner was not fully removed, just undone a bit, put on gasget goo, re-tighten that would be fine. I am sending the how in a word doc to Russell. UK
24-07-2011, 11:46 AM | #22 | ||
AU DIE HARD
Yeah the quick fix would be to just loosen the outer ring off 3 turns clean and do 2 laps with teflon tape an re seal it but wares the fun in that when you can pull it apart and see hows it works (or doesn't any more) besides that when have we ever done anything the easy way
16-10-2011, 03:02 PM | #23 | ||
I'd rather be cycling
Newbie on this forum, sorry if this has been covered before.
I don't mean to be unduly argumentative, BUT, I just found the source of an odd oil leak on my AU-II with 230,000km (I've had it since buying it as a demonstrator in 2000). The leak seemed to be from the timing cover, but once I got the PS pump and mounting bracket off, that area all looked pretty clean. My leak was associated with the lowest mounting bolt for the PS Pump mounting bracket. That bolt is smaller than the other two - a 10mm head and about 4" long. The hole in the bracket and the block are the same size as for the other (larger) mounting bolts, so there is lots of space for oil to leak out. You can see the amount of oil that's come out onto the white tissue underneath the bolt, and some of the spray on the engine itself. I don't know if there was originally a seal or a sleeve installed in the block, but if there was it's not there now. I loaded some (6) O-rings onto the bolt (which has a step-down in the shaft diameter about 12mm from the head). I got these O-rings from a champion assortment (blister pack) available from your favourite auto store. Bought two sets and loaded two sets of O-rings in the following sizes and order - first on was the 3/16", then the 7/32" and finally the 1/4". You can see that the rings protrude beyond the mounting bracket and will extend into the engine when the whole lot is assembled again. It all seems to seal now, and no evidence of leaks so far. I did wonder if this is leaking because the crankcase pressure is higher than normal, perhaps a broken PC valve? Last edited by mccoy54wru; 16-10-2011 at 03:24 PM. Reason: trying to get images to show in-line |
5 users like this post: |
22-10-2011, 01:39 PM | #24 | ||
That is a very long bolt isn't! Good idea.
UK
22-10-2011, 02:01 PM | #25 | ||
Nice write up mccoy54wru, My AU II had the exact same problem as yours. My mechanic just gooped it up and its been fine ever since. I like your fix better tho...
22-12-2011, 04:40 PM | #26 | ||
WEST australia
my bf is leaking aswell just wandering if it would be similar fix like this??
22-12-2011, 08:25 PM | #27 | ||
Related note, when I was changing the belt tensioner pulleys, which required removing the tensioner assembly, one of the (very long) bolts holding it onto the block had engine oil on it. Had to be very careful not to get any on the belt or pulleys.
Are these holes used when casting the block or is there some other reason that the engine designers chose to have a bolt hole go right through to an oil gallery? |
23-12-2011, 01:13 AM | #28 | ||
Well, my fix didn't last. The O-rings move along the shaft too much. Spoke to a mechanic friend who advised (as others have here) sealing with silicon after a jolly good clean of the excess oil. So far (about 3 weeks) there is no more leak.
@unko_sim - If the BA looks the same, then I would expect the fix will be the same. Mine's 400 miles away so I can't go and take a look, sorry. |
23-12-2011, 08:39 AM | #29 | ||
My old man just bought a AU S2 Wagon Dedicated Gas, it has the same problem as mine did, just a loose timing chain tensioner bolt, it needed about half a turn just to nip it up nothing to tight.. seems it has been leaking a while it was a mess and a half to clean up..
and the idler bearing at the top had packed it in.. which was spraying greese out by the look of it.. |
24-12-2011, 07:12 PM | #30 | ||
be careful messing around with the timing chain tensioner .
you need that special 2 prong tool to do it up(releasing the the tensioner itself with the alum key and that) .if you just do it up by the centre bolt as in UK's pic 10 ,be very careful not to over tighten it.if you wind that in it will over tension your timing chain and you'l chew your guide out !! i learn't the hard way a few years back.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
