Old 17-09-2017, 10:10 AM   #121
scrisford
Default Re: OBD II reader and Forscan program.
Originally Posted by TimXR6 View Post
Just received my ELM327 scanner from ebay
Downloaded Forscan to laptop
Tried to run it on my BF11 Turbo- Wont connect to vehicle.
Try it on my AU11 XR8 and works no problem.
Have tried it a few times now on the BF and keep getting 'cant connect to vehicle'.
The scanner is getting power, as it lights up. When first plugged in, it lights up green then scales back to 2 red lights. It does this on the xr8 as well.
Any ideas? Not sure where to start.
cheers
TIMxr6,
I have AU11 XR8, i have tried other code scanners. Exactly which code scanner did you buy. Hopefully 4 time lucky?
scrisford is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2017, 12:31 AM   #122
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
This may help you,
http://fordforums.com.au/showpost.ph...&postcount=603
BFWSMhttps://fordforums.com.au/vbportal/v...articleid=1708
ZF:http://fordforums.com.au/wsmpub/bf/307-01B.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/Up 2019:Winner 2023:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate 1200cc Manual.
BFIIGhiaZF6 is offline   Reply With Quote Multi-Quote with this Post
