a mate off mine is currently thinking bout putting a nissan RB@%DET into his AU series 2 forte.
i personally think he should just rebuild his I6 because it rooted atm wat u guys think? hes getting the RB25 front cut very cheap and his father is mechanic and brother a auto electrician so the conversion wnt cost much honest opion plz? |
Was V6corp
Id rebuild the I6....... Mainly becuase people shouldnt mix imports with homemade.
Ford = Homemade Other = Import :P But its his cash.......... ![]()
Car: 99 AU I Forte Sedan Colour: Blue Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash Bling Mods: Tinted Windows; JVC CD/DVD HU Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags |
Nitrous Junkie
Given the success the 4.0L is having with forced induction of late wouldn't it be easier to get the 4.0L rebuilt and whack a turbo on it. If he wants an RB tell him to get a VL or a skyline but don't destroy a perfectly good ford by putting a nissan engine in it.
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2 |
Audi S3
its his car. if he can do it- go for it. at least its different.
Would be an interesting conversion.. I wouldnt use the RB25 though.
But like its been said, with a high success rate of turboing the 4L theres no real point. RB26DETT on the other hand.... lol or how about a Twin turbo 20b triple rotor? :P |
Bseries Moderator
unless the mechanic can fabricate custom engine mounts and maybe a sump then it wont cost much.
but count in an ecu if your not using standard pooline one custom tailshaft or belhousing if hes keeping the box. engineers cert, custom exhaust. also the intake manifold might foul against the steering column may also have problems with fitting against the firewall or trans fitting in the tunnel that will depend on the engine mounts used though.
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
My question - why?
He already has be backing expertise to rebuild the engine cheap and put in a external ECU like a Haltech. All you then have to worry about if you want to turbo the Falcon engine is cutting and modding the exhaust and putting the flanges for fitting the turbo, piping for intake to turbo to fmic to tb, change of vac lines to before the turbo, oil lines etc. With Nissan RB engine, you have to worry about fitting, mounts, gearbox, tailshaft, electrics, cooling system, exhaust, steering rack, possibly suspension, intake pipes, FMIC, ECU, sensors and so on. Each of them posing a myriad of issues to get over Tell your mate to stop dreaming of being a F&F Tokyo Drift wannabe and to wake up to common sense. |
Nitrous Junkie
Sure its different but with the time and money spent on doing it for not much gain if any it just wouldn't be worth it imho.
*Edit* BlackLS beat me to it, well said mate.
www.TUFFCARPARTS.com
The newest RB25's go right up to 2001ish, however most front cuts out there are of the 93-94 variety, thus making the conversion into an AU2 illegal.
Not only that, but RB25s even in modified form don't have much low down urge which is what you need to get a falcon moving. In there natural home in an R33 they're fine as they only have to move 1360 odd kilos, but in a falcon, it would be gutless. For the price of what the front cut, and conversion costs (yes, I know you mentioned he's got help, but major conversions like this ALWAYS soak up big dollars and present major hassles along the way), he could very easily boost the AU 6 and have a torque monster which will also destroy most RB25s out there. Engineering a boosted AU engine versus a complete conversion will also be much easier. As a bonus he'll even have change at the end! |
yeh that wat i thought but for the money he has i think putting the RB into would b the faster of the 2? and performance paarts for the RB r alot cheap and more common im starting to like the idea to b honest
Bseries Moderator
its his car he can do what he wants but what has the rb25 got over the i6 other than having a turbo on the side standard?
i dont know what the rb25 bottom end is like but the 4L has 4 bolt mains factory which is more valuable than most people recognise hes better off getting the 4L rebuilt tough imo. the rb25 may work out cheaper (which i highly doubt cos of the custom bits needed) but will be a great big headf*k and i wouldnt be surprised if it would be struggling to crack a 14 second pass. sure its got a hair dryer but its only 2.5L of capacity. always a big downfall. a turbo 4l would make the rb25 face the wall with its hands behind its head. not worth the effort unless your going for a rb26 or 2jz motor if you are going for the jap motor. whos not to say the front cuts motor is on the way out either? it is second hand after all. dont say its got xxxxxx k's its only new. give me a motor and ill blow the sucker up without doing any k's.
#12 | ||
Bseries Moderator
are they really cheaper?
what parts are we talking? ever priced up tomei cams for a jap motor? adjustable cam gears? stroker kits and forged pistons? get prices on those and see what the cost difference for jap vs oz is.... as for things like injectors, fuel regs and pumps, turbos, air filters is all universal.
XY Driv3r
That is certainly something with a twist...
A couple of years ago I was organising an rb25det conversion into my xf through Brescianni Racing. Quoted with aftermarket computer, fuel pump and reg , c4 auto with histall and nine inch was goin to hit me 8500gs... Which i know is expensive but was going to be different ... Fortunately i saw the light and bought a V8! :evil3:
#14 | ||
XY Driv3r
But given that the ford 6 are damn strong i say why not!
(sorry for double post computer is driving me crazy :jab: )
#15 | ||
Winter all year round
In stock terms
AUII I6 Intec 157kw 357Nm Torque R33 GTS-T RB25T 186kw 294Nm Torque AUII weighs 1545kg & R33 Coupe 1310kg The skyline would be much quicker because of the low weight, but putting that motor into a falcon won't achieve much, the following however is more worthwhile BA I6 4.0L Turbo 240kw 450Nm Torque I'll admit the syklines are a cult car, addictive and the RB's have a unique sound, but if that is what he is after then sell the falcon & get a skyline. Just my 2cents, Adrian.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it. Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC |
#16 | ||
Bseries Moderator
the ba turbo will pose ecu dramas in an au you will NEED an aftermarket ecu theres no question about it that would probably be the most expensive way out but the best honestly.
ba turbo in 33 coupe would be more worthwhile :P
#17 | ||
![]() Join Date: Jan 2005
RB25 stock puts out less power than an AU I6, so what's the point. Better off spending money on rebuilding and toughening up the 4.0 I6, even turbo it. For someone that could do it themselves, $4500 is a reasonable budget and the car will pull around 200rwkw easy (equivalent to around 260 fwkw).
#18 | ||
I still can't see an advantage to this conversion
#19 | ||
he wants sumthing different i supose i dunno he a confuseing lad! i told him to join up up here so he can do his talking
#20 | |||
#21 | |||
Audi S3
#22 | ||
Right out sideways
LOL glenn, good call son
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#23 | |||
#24 | ||
More like shooting himself in the foot!!!!
#25 | ||
turboute
Best engine to use would be a 2JZ from an Aristo, 240 or so kW, with minor mods it could go up to 270 or more - std internals good for at least 600hp and there have been cars putting out over 800hp with the std internals (and a very very good tune). best thing is these cuts can be had for about 4k. RB25 is the equivalent of a jap taxi motor it's internals are cheap and they do not last, stupid thing is they also still cost 4k or even more.
Other options I would suggest are - Nissan VH45DE - 4.5L 206 kW (probably more) can be had for about 3k, or a toyota 1UZDE 4.0L again 200ish kW |
#26 | |||
#27 | ||
Ripping it up
Bah... 200kw fom a turboi motor, putting out less torque in a 'coon?
Cmon! The torque is what drives us. Turbo the AU, and then youll have some fun! |
#28 | ||
Spin 'em Habib !
ive seen a f100 with a Scania BigRig 12lt Truck Motor complete with Intercooler and Turbo , slow but looked cool
AU2PWR |
#29 | ||
Something similar has been done before on this forum I think. I remember seeing a turbo nissan motor in an EB and a turbo soarer motor in an ED. I even seen a lexus V8 go into an ED. Personally I wouldn't do it. I've gone down the turbo 4.0 route. Stacks of low down torque.
That and I like the idea of being able to go to any wrecker and pick up a decent motor for $500. The 4.0 would seem plenty strong. Some are running decent boost on an otherwise stock motor and these things are remarkably hanging together. |
