Old 02-06-2012, 02:19 AM   #1
graham7773
Default Ford Telstar windscreen
Bank account is a bit low and I need to replace my 1993 AX Ford Telstar's front windscreen. Do any of the members have any guiding thoughts. A step-by-step would be good. Any pitfalls to watch for would be appreciated
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 01:25 PM   #2
graham7773
Default Re: Ford Telstar windscreen
How many members are there on these FF forums? And not one has any idea how to change a 1993 Ford Telstar windscreen? Or is there some secret method being protected. Something like "paintless dent removal". I have tried to watch these guys do their work and they seem to find something else to do on most occasions. Paranoia? Of course!
Old 03-06-2012, 01:37 PM   #3
IceValk85
MY2010 SV6 SIDI -Black-
more like needing more than 12 hours for someone to respond bud, it is sunday you know.
IceValk85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 01:47 PM   #4
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
No need to get grumpy, if there was a member who read this and could help then they would of replied. But alot of people only read threads that grab their attention and unfortunatly the telstar isnt the most appealing subject to read.
But of the tens of thousands of members on here alot of them have probably never had to replace a window and those that have had to replace them usually pay a proffesional to do it for them.
It makes sence to because to tools they use to remove and replace a window correctly and proffesionally are usually worth more then fitting the window itself.
Try contacting a few window replacement mobs and explain your situation, some would rather do the job and get payed off in installments than not get the job at all. If your lucky one of them will have an easydebit system where you agree on paying a certain amount at intervaks that suit both parties.
We do this at work where a customer has an unexpected breakdown and cannot afford the job straight up. We do it, they fill out some paper work and the job gets payed off over time.
Or you could just google it or search youtube
Good luck with it
270rwkw BA XR8
http://www.fordforums.com.au/showthread.php?t=11339147
XARATE is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 03:32 PM   #5
graham7773
Thanks for the responses though not helpful. By the way, 1:19 am Sat to 1:19 am Sun = 24 hours+ 11 hours to 12:25 pm Sunday = 35 hours. Googled unsuccessfully...
The second post was tongue in cheek, (note paranoia) trying to be humorous. Ah well. No sense of humor either. Myself, my son or my grandson do most of the mechanical work on my car and I have changed windscreens before but the Telstar is a bit different and I am looking for a few pointers. Paying somebody more than $100 an hour for something I can do myself, with some guideance, seems a bit pointless to me on an age pension. Just another thought, what are people doing on this nice rainy Sunday? Out chasing cane toads?
Old 03-06-2012, 03:55 PM   #6
The Yeti
The Yeti's Avatar
Assuming its a glue in type it's not rocket science
Pop the corner up I used to use wire as a cuter so you just run some through the bit you poped up and get some one on the inside and run it round the adhesive till you've done a lap then lift it out
Clean the old sealer off and put a bead of sikaflex around (a good healthy bead say 1/2 inch sort of thing then drop the new one in ensuring that it doesn't come in to contact with the metal (A Pillars roof and fire wall) and space it evenly so the surround will go back on and not look stupid (a couple of bits of vacuume line does the trick until the sikaflex sets)
DON'T use generic silicon as this promotes rust
Probably wouldn't hurt to phone around as the price for a windscreen bloke to come out and stick in a new one isn't that bad (windscreens obrian will be the dearest you can find)
Also wear a P2 dust mask & eye protection when you do this as you pull the old one out you can get fine fragments of glass dust and that does all sorts of messy stuff to your eyes and it's believed that this same fine dust will become the next asbestos
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
