Old 08-04-2006, 08:21 AM   #1
nat_daly
Nat D
nat_daly's Avatar
Default heavy throttle?
ok the ed im looking at purchasing has an extremely heavy throttle, what could be the cause of this?? how much to fix each cause?
if anyone can help that would be good.
old ride#1: ED XR6 5 speed-gone to new home:(
old ride#2:dumped EL fairmont 5l
new ride: Winter white AU2 XR8-manual
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 08:46 AM   #2
nat_daly
Nat D
nat_daly's Avatar
ive been told that it is the throttle cable ould be old, is this correct?
Old 08-04-2006, 09:42 AM   #3
ltd
Force Fed Fords
ltd's Avatar
yes. Feel around the throttle body and push the butterfly actuator manually. If it has no restriction, then you know it's the cable. I'd also check around the top of the pedal for loose carpet, underlay etc, check that nothing there is binding too. Good Luck
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
