Old 11-11-2023, 11:59 AM   #1
Peter l
Default Condenser
Hi all, still got EB 1 which is for sale many lookers but no offers over 5K.
Went to regals and was informed that o rings need replacing now got told that the condenser needs replacing however could they be mistaken due to no fan speed control Your help please as selling car only due to illness thanks Peter
Peter l is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2023, 02:17 PM   #2
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Default Re: Condenser
The condenser could be damaged, the fan speed control is usually the fan speed resistor like this one
https://www.ebay.com.au/itm/38606143...Bk9SR8KavsL3Yg
seeing you are selling a second hand one that works will be ok.
I would just be asking the question as what is the problem with the condensor?
Old 11-11-2023, 02:43 PM   #3
Peter l
What I need is Control Blower motor Speed ford part. 19E624A
If the condenser is faulty then I assumed that coolant/ radiator would overheat ?
Old 11-11-2023, 02:53 PM   #4
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Condenser is part of the air-conditioning, the radiator is what holds the coolant
Old 11-11-2023, 06:53 PM   #5
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
You sure they said condenser and not dryer/receiver?
Reason I ask is if EB1 runs R12 gas you change the dryer/receiver before converting to R134a.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2023, 09:31 AM   #6
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
And all the AC hoses - if you put R134a in an R12 system you'll lose refrigerant through the hoses, R134a hoses have an extra barrier to prevent it leaking out through the wall of the hose compared to ye olde R12 jobs.
Just recharge it with Hychill Minus 30 after rectifying issues, it's a drop in replacement for both R12 and R134a, it's perfect for older cars.
https://hychill.com.au/products/minus-30
Old 12-11-2023, 11:16 AM   #7
mad2
Regular...with metamusal
that would depend on if it's a base model or a Fairmont.
