Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
12-08-2007, 09:15 AM | #31 | |||
Enter my weight (4188lbs) and my best mph(112.77) and you will see that the power is close towhat the Dyno is recording.. http://www.modulardepot.com/hpc.php I think Chris and Craig could explain better then me.... I'm still a newby at Drag racing... Last edited by jabba; 12-08-2007 at 09:24 AM. |
12-08-2007, 09:17 AM | #32 | ||
SLYME UTE
Well done on the time. . .
dute is big and black now. . . . . : |
12-08-2007, 10:01 AM | #33 | |||
Location: Working, chasing after my daughter and working
I have done many a pass at around 112mph then got the changes right and jumped straight to 115-116mph and once you get it right you will know straight away as it feels real good/ quick between gears. Your 1/2 track mph will go up with a better 60ft/gears changes but end mph will only vary depending on where you change gears and how well you change. |
12-08-2007, 12:41 PM | #34 | ||
Thanks for the good advice Wade... At the moment I am shooting in the dark with my gear changes. As I said in an earler post my tacko is not keeping up with actual engine speed, so I don't quiet know what rpm's I am shifting at.. But I dare say I might be holding gear to long... My next mod for the ute is a shift light to help perfect my gear shift.. I realy want a 114mph out off my ute in street trim. But I think I need to look over the tune to find some extra top end..
12-08-2007, 12:42 PM | #35 | ||
RIP Craig - 13/11/08
Quadcams nailed it, auto's are easy to squirt down a track, real driving is a manual and a 5speed BA is probably the worst even with a good clutch and rip shifter they are just ordinary, that's why when i went racing in my old XT 3V i would swap the six speeder out of my ute.
It's not the 60ft that makes the MPH increase it's the whole run and with a manual it's even harder to get consistency. Riding the clutch out of the hole is much better and once mastered it makes it so much better. |
12-08-2007, 02:14 PM | #36 | |||
keep at it jabba, Paul has done a good job with your tune, cars showing good numbers for its setup. About the tacho, Vern mentioned he had this issue, myself first gets a little blury but after that all good, suppose I've just gotten use to it. Last edited by Quadcams; 12-08-2007 at 02:23 PM. |
12-08-2007, 02:20 PM | #37 | ||
Someone once described the gearchange in the T3650 5-speeds in the BA V8's like a d!ck in a shirtsleeve, it's dead right and even with a short shift it still can be hit and miss.
Once you get your rpm tacho working maybe try a couple of runs each shifting gears at the rpm in which you make your most power (check dyno sheet), and a little higher and see how it goes. You have the 4.11's don't you Matt? So you would into 4th well before the finish? |
12-08-2007, 03:05 PM | #38 | ||
No, I have 3.7's Rod... The time I set my previous PB 12.55 @110 I was hitting the 7000rpm rev limiter 40m before the finish line... So We we extended the rev limit to 7500 to get over the line in 3rd without hitting the limiter, and we thought with the extra power we would get 114mph easy. But what we found last Wednesday was I was right on 7000rpm going over the finish line, insted off hittting 7000 40m before it... (Tacko reads correct in 3rd gear)
12-08-2007, 03:13 PM | #39 | ||
The 3:23's in the BA did the same, the limiter right at the finish, going to 4th wasted time. I went to 3:46's, as the shorter ratio's weren't available back then, so it allowed to get into 4th more before the finish and change from 3rd earlier
12-08-2007, 06:28 PM | #40 | |||
BOSS 5.4L Enthusiast
12-08-2007, 07:28 PM | #41 | |||
KenneBell Australia
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
12-08-2007, 08:18 PM | #42 | |||
12-08-2007, 08:56 PM | #43 | |||
love being blown
we had a side by side run early in the night with a 12.5 to Jabba and a 12.7 to me he is very quick off the line thats for sure congrats Jabba great time mate glad i was there to share it with you : : :
GT-P 2003 + XR8 Supercharged Ute 260+ BOSS : : :sm_headba : New PB 12.4 @ 108mph : : www.xrclub.com.au |
12-08-2007, 09:50 PM | #44 | |||
12-08-2007, 10:27 PM | #45 | ||
I noticed two years ago that all the quickest and fastest LS1's that were manuals were in 4th gear just after half track. My ute with 4.10's i was almost the same as the LS1's and my MPH was always around 113 - 115. Having said all that MPH to me is not that exciting (i know what my car has in the way of power) i just want ET slips.
Most records in Drag Racing are remembered for ET and firsts. |
13-08-2007, 09:10 AM | #46 | |||
KenneBell Australia
13-08-2007, 06:32 PM | #47 | ||
Hey Graig, it was good chatting with you today, and thanks for the tips to get over the line quicker.. Hopefully I will have the shift light in a few weeks, and as we discussed, here is my Dyno read out for you to work out the optimum shift points... Chris feel free to comment if you like..
Oh, and see that little dip at 6200.. Paul and tim wanted to put a little more timing in there.. But it was my call to leave it as it is.. In case off bad fuel I didn't want it to pink at that rpm.. Last edited by jabba; 13-08-2007 at 06:38 PM. |
13-08-2007, 06:55 PM | #48 | ||
Broken
Hi Jabba, I guess that's end of circuit for a while. Very good 1/4 mile time.
Exactly how hard are you able to spin your motor now that it's been built ? I had to re read your reference to 7500 to be sure ! That's a tuff n/a Boss you have there.
The Scud GT 11.4 @ 128, 1.88 60ft. |
13-08-2007, 07:37 PM | #49 | |||
Gone of the circuit a bit, mainly because how hard the ute is going, I liturly can not stop it at the end off the straights. I need much bigger brakes and they cost heaps.. Also I won't put faith in a set off cheapo brake upgrades either. For me, it a case of the best stoppers or nothing at all.. And at a time were I want to spend money on my house, and I also just blew up my boat motor, and that's a big $ item. (what is it with me and blowing up motors). I don't want to spend too much more on the ute.... Besides the Orion is comming out soon.... Supercharged Superpursuit Orion,, Yes please |
13-08-2007, 07:39 PM | #50 | ||
You can't help it though if a cruiser swamps your boat though!
13-08-2007, 09:09 PM | #51 | |||
13-08-2007, 10:24 PM | #52 | |||
love being blown
14-08-2007, 03:51 AM | #53 | ||
hunting 300kw's
6900 looks like a good place to change
current ride: '04 XR6 Turbo, Phantom, Premium sound.BluePower Enhanced 236.9rwkw 8psi DAMN VALVE SPRINGS (stock 13.82 @ 106.08 HPR)(8psi 13.29 @ 103.93) '99 r8 clubsport, leather, sunroof, 6speed, yeah the turbo is faster..... |
14-08-2007, 09:54 AM | #54 | ||
Chris & Craig will have the magic answer but looking at the chart I'll back 6100rpm to make the most of the hp and changing into the highest torque range.
14-08-2007, 06:07 PM | #55 | ||
Looking at the dyno sheet there Jabba i would be shifting at 5800 - 5900 or maybe 6000, do three runs with 1 run shifting at nothing but 5800, the next at 5900 and the last at 6000 and compare notes.
It's all about trial and error. Cheers Craig |
14-08-2007, 06:58 PM | #56 | ||
Cheers Craig... I will take your advice... Problem is I very rarely get to do any more then 3 runs each time I go out to Willowbank, even on a Wednesday night it's crowded.... But I will do my best.
I replayed my 1st to 2nd gear change over and over to pick faults in my driving, and I definitely think I am holding 1st gear way to long. And if that is the case it is probably the same for 2nd to 3rd... So now I think if I follow your directions and shift earlier I will be in 4th at about 300m... |
14-08-2007, 07:05 PM | #57 | |||
Well done. Just like a good bottle of red, you'll only get better with time!
1994 XR8 Sprint |
14-08-2007, 07:51 PM | #58 | |||
