Old 07-03-2015, 08:44 PM   #1
Otters78
Default Toyota T50
Chaps,
My first post, thanks for letting me tag along.
I'm considering popping in a toyota T50 gearbox in a mk. II ford escort panel van running a 1600 crossflow.
How involved is the process? I've tried finding links on the forum but have come up short.
All advice gratefully accepted.
Cheers.
Otters78 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2015, 10:56 PM   #2
Default Re: Toyota T50
Bell housing, clutch plate, pressure plate, modified thrust bearing, speedo cable, modified cross member should be about it.
Someone probably sells it all.
Old 08-03-2015, 12:31 AM   #3
Otters78
Mighty obliged to you!
Cheers.
Old 09-03-2015, 10:01 AM   #4
dirty hands
Over Thinker
dirty hands's Avatar
post back what starter motor you used
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2015, 11:21 AM   #5
Otters78
I'll let you know...once I pick up the car. I've just recently bought the panel van and I'm a little green behind the ears about it all. So, I'm doing my research.
I'll let you know once I go get her.
Old 09-03-2015, 08:03 PM   #6
dirty hands
Over Thinker
one like this ?
they have got a stupid lower ball joint arm type thingy with a bush
Old 09-03-2015, 08:53 PM   #7
Otters78
That be the one, but I got windows along the side. '81 model.
So, do you think it's worth effort?
Old 09-03-2015, 10:51 PM   #8
dirty hands
Over Thinker
yes ..do a lot of research about this power train set up you like
these escorts did have a 2 ltr motor fitted
the diffs are very good
1600 cross flow a grunt motor
with a 4 speed box its still ok
still looking at this question of the T50
http://www.gearboxconversion.com/Toyota_T50.html
with the T50 box you might need a custom drive shaft built .... not sure myself .
you might want a brake upgrade later .
.only drums at the back small disc at the front and struts set up
