26-04-2015, 07:01 PM | #1 | ||
Thinking of starting a new project with an xr6 turbo into a cortina but has recently hit the skids as it looks like you can't fit a 4.0 turbo legally into a 1200kg car. According to the qld main roads website for a car over 1000 kg the turbo engine size multiplication is only 3 x the body weight.
I had originally thought as the later models came out with the big six you would have been able to get a turbo' done complianced . Has any one heard any different? |
26-04-2015, 07:06 PM | #2 | ||
Over Thinker
that 1000 kg rule still stands for a street registered car as far as i know
nothing stopping you to build it for non road use anything re check with any authorized engineer QLD T/portlink http://www.tmr.qld.gov.au/Safety/Veh...fications.aspx
My car goes Brumm Brumm Last edited by dirty hands; 26-04-2015 at 07:17 PM. |
26-04-2015, 07:59 PM | #3 | ||
If it is a no go then a 2jz it is.
04-05-2015, 07:09 PM | #4 | ||
A modded naturally aspirated ba engine would go fantastic in a cortina.
07-05-2015, 09:04 PM | #5 | ||
Really after something factory turbo that makes good power with a little tickle.
Getting a 2jz to around 500hp seems reasonably achievable with a few grand thrown at it and they are a smaller engine, starting to lean that way now. Also something a little different. |
31-08-2015, 10:51 AM | #6 | ||
Do some research.
If you want it fairly legal you might be better off starting with the single turbo 1JZ type motor. |
