whatts the ppoint of this disc between the rim and the brake rotors?
does it do any particular job? cheers |
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
I think you are talking about a plate that ford used to hide rusty rotors that came straight from the factory! Only surface rust though, nothing to worry about.
AKA MYTE8
I think its also meant to help keep brake dust off your rims.
#4 | |||
Virtuous Bogan (TM)
I see you....
These discs get blamed for overheating brakes....not recommended.
Seemed to be bloody effective with dust though |
MYEB
take them off ,will also help keep your brakes cooler(i think??)
Spin 'em Habib !
Drill em and paint em Gold , Instant Gold Rotors ...
AU2PWR |
With da Warlords
hehe, just finished spraying mine the other day, guess what colour lol
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
Flying high...
I think it was also designed to space the wheel out just that little bit. My AU doesnt have it, because it did get the Tickford rims from factory, but there is like a spacer thing about 2mm thick over the studs.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
