could someone please give me some idea as to what could be wrong..
when applying pressure to brake pedal, coming to a stop ,seem to be losing revs and intermitentaly completey stalls.. starts straght away though.. any thoughts would be appreciated.. thankyou kumbi |
#2 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Poppa
Was having similar troubles once, could be the alternator on its way out...
AUII I6 XL Ute - AU XR8 17's, skirts, lowered |
does it restart with your foot on the brake?
LIFELONG DJR SUPPORTER
Sounds like a vaccuum leak. The assistance provided to your braking system is supplied using a vaccuum, hence the black bit behind your brake master cylinder being called a vaccuum booster.
If it is holed, you will cause a vaccuum leak, and the engine requires vaccuum to run. the symptom you mention could be caused by a major leak somewhere. is the dipstick fitted properly, and the seal intact, is the oil filler cap fittedproperly, and seal intact. As my useless freind Useless mentioned, could be a 100 things. Hope to have been some assistance.
Member 178
Brake booster is dead.
Force Fed Fords
Had this problem when I had removed unichip to sell from EL, had modified cam, and when I braked would stall.
#8 | ||||
To shreads you say?!
Yeah, sounds like your brake booster is stuffed. A good way to check is to start the car and let it idle while stationary, and see if the engine stalls or drops the revs a lot when you press on the brake pedal.
BAII XR6 Ute (manual) Winter white. Quote:
