R.I.P. Maggie
Hi All
Is it possiable that all instrument cluster light globes could blow at once. I have lost all lights even the LCD screen, The only ones working are the warning lights, the clock and the indicators. BTW the shifter light is not working either. Fuses are all good, what else should I check. Im going to check the globes today. Any advice appreciated
AUII XR8 200Kw Ute FG XR6T 1976 289 Mustang (Gone) |
Spanner Thrower
It is possible, had it happen in mine. I don't know if yours would be the same (mine burnt the circuit board inside the cluster)
Do you still have the a/c buttons or any middle dash ones light up at night?
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
only if your car was struck by lightning -
recheck fuses with a test light - do tail lights work/ does tail light relay (inside fuse box) click when turning tail lights on/off ? possible fault in head light switch - |
FG XR50 TURBO
![]() Join Date: Apr 2009
May be a blown tail light fuse as i think they run of the same fuse could be wrong tho
cheers Dean |
R.I.P. Maggie
Tail lights ok, all the lights in cluster work except for the illunination lights, so the hand brake ect work. The AC light is on. Im about to check fuses again
Thanks guys
R.I.P. Maggie
OK boys, issue sorted. I dont want to go into detail, however I will say that I will be wearing my glasses next time I have to check fuses and leave it that.
Thanks for the replies
FG XR50 TURBO
Glad you got it sorted out
