All Bran = Regular Member
I'll be fitting suspension bits next weekend (finally, George) and rear slotted rotors. While I'm at it I'll have a go at adjusting handbrake - mine doesn't work and also does the shhh, shhh, shhh thing.
Does anyone have a formula for a successful handbrake adjustment (au3) which lasts (for more than a couple of weeks)? (I did a search but I'm interested in results that last for more than a few days) Thanks... |
#2 | |||
Re adjust the cable at the handle. The trick is not to have a low handle or you will get the rubbing sound. Get it so it is holding the car at about 2/3 to 3/4 handle
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
the other thing to remember is, when you have adjusted it properly, pull it up just far enough for it to hold, don't yank it up all the time or you will have to readjust it again in no time
ok, thanks guys. I'll let you know in a month whether it was successful ;)
Cookie Monster
Hi All,
I had the annoying sh sh sh sound for 2 years. I was told it could not be fixed. I machined disks and changed the handbrake shoes and also had the handbrake adjusted. It did not fix it.. :( I then came a cross a post that detailed that to eliminate the noise you need to file a 45 degree chamfer on all the edges of the handbrake shoe. I did this with a file and it worked!! I have done 3,000 kms since this mod and it is all perfect no noise and the handbrake grips great. I adjusted the handbrake so it grips at about 5 clicks from full release. It works very well. I am not sure who posted the fix for the sh shs sh noise but I am eternally grateful to them. Apparently he was given the tip by some guy at the local Tyrepower. Worked a treat for me and it took only 1 hour to do both sides. While you are at it remove the threaded adjusters for the handbrake shoe and clean and regrease them as they may be sticky (mine were) Good Luck Cheers Engineer ![]() |
#6 | |||
![]() Join Date: Jan 2005
So do you have to chamfer both sides of the shoe or just the outside?
While we are on the subject of handbrakes, in more fortunate times I had a succession of Falcon work cars. With every one and now with my own AU, on a slope after I have put on the handbrake the car always moves downhill a bit.
I guess the car moves until the transmission park pin ("detent"?) engages. How come the car moves at all?
. . Rob Ewart Bog standard silver BF Wagon, except for the Elvis doll ![]() Victorian Rock'n'Roll Dance Association www.VRRDA.com.au 2015 Victorian Rock'n'Roll Dance State Championships 23 May 2015, Furlan Club, Thornbury |
I must be one of the lucky ones ... the handbrake on my ute has worked perfectly for me ... not an issue at all.
#10 | |||
Ran out of time for handbrake adjustment but will find time over the next couple of weeks Thanks for the reminder. |
