Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 14-03-2013, 08:53 PM   #1
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Tune for E Series Falcons?
Hey guys, just curious if you do tuning on E series Falcons, in particular with the TI Performance J3 tuning stuff?
I've got an EL Fairmont Ghia with:
Pacemaker 4499s
High flow cat
2.5" cat back exhaust
ported/polished head
cammed
stiffer valve springs
and I'm running slightly higher compression with a decked head and AU Falcon head gasket.
I'm looking to get it tuned for 98.
Would I get any benefits out of a tune on these modifications?
Thanks much.
Old 15-03-2013, 04:53 PM   #2
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Default Re: Tune for E Series Falcons?
From the archive's Damo.
http://www.fordforums.com.au/showthread.php?t=70949
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2013, 07:38 PM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
You will always see improvement with a dyno tune over the stock ecu after you have done the mods you have done
The ti performance or moates j3 chips are very capable of helping you car to peform at it's maximum potential.
If your not sure about a dyno tune get it on a dyno for a few runs to see what the afr's are doing - if they run lean or too rich at any rpm then a dyno tune will benefit the performance of your car
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2013, 12:54 PM   #4
Franco Cozzo
Thailand Specials
Originally Posted by Bluepower Rocks View Post
Thanks mate, only SCT tunes?
I like the idea of the TI Performance J3 because they can now control transmission, they can alter how hard it shifts depending on how hard you are on the accelerator, which I like the idea of, because these 4 speeds are hopeless, it drives nicely potting about, but put your foot into it, and it thinks for a few seconds before doing something.
I'll get it done anyway because I've got a few niggly issues and I've gone this far, its not a good idea to do this stuff half assed.
