Old 02-06-2011, 11:54 AM   #1
whoopwhoop
Default au horn switch
Can anyone direct me to info replacing horn switch ford au. I can't get search to work..
whoopwhoop is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 12:43 PM   #2
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Default Re: au horn switch
The horn and airbag is a complete unit. I replaced it myself, but needed a special tool. It is a security / airbag type allen key with a 5 or 6 point head (the non standard number!) which also has an indent / hole in it. There are 2 screws/bolts on either side of the steering column with covers / caps over them.
I bought a second hand complete unit (airbag / horn / centre) from my local Ford wrecker. Cost $50 18mths ago.
A mechanic will know how to do it, should take 15minutes. 5 minutes is the safety precaution of disconnecting battery. Apply brakes to remove any electrical energy stored.
If you do it yourself, just be careful with the cruise control and airbag/horn wires. Airbags are an explosive device!
Reason for replacement was horn coming on randomly. Did it a couple of times. Cause: Due to my AU being parked on the street the heat build up in the car eventually deteriorates the foam insulation between the contact points of the horn button.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 01:02 PM   #3
whoopwhoop
Cheers that is great advice .i am pretty sure it is the switch that is faulty .why does the horn have 2 terminals?
I think I tried to run a wire straight from battery to horn but didn't work. I did use multimeter and had no volts at horn. The Fuse is ok.
Old 02-06-2011, 06:41 PM   #4
FGII-XR6
FGII-XR6's Avatar
the horn switch drives a relay the fault could be there there is no power at the horn till the relay switches +12V to it the horn switch actually goes to the BCM first so the way it goes is switch - BCM - relay - horn
[SIGPIC][/SIGPIC]
Rides:
Old 02-06-2011, 07:09 PM   #5
FGII-XR6
FGII-XR6's Avatar
if you have an au this is the best place to get advice http://www.fordforums.com.au/forumdisplay.php?f=241
[SIGPIC][/SIGPIC]
Rides:
