25-10-2012, 03:40 AM | #1 | ||
Although it looks impressive you have to ask if GM will ever move into the modern era and make the jump from big cube pushrod engines and move to modern DOHC technology.
http://blogs.hotrod.com/chevrolet-de...ine-38589.html |
25-10-2012, 04:42 AM | #2 | ||
Supercharged Mang-mobile
The Gen 5 LT1 finally emerges.
This engine seems like it has quite abit of potential. Will be very interesting to see how it goes in the Commodore body. Based on that article, I still believe the Miami to be the greater engine.
09/00 VX HSV XU6 Build #0001 of 0171 http://fordforums.com.au/showthread....09#post5571209 -- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16 Tickford EL Falcon XR6 RIP -- Factory Manual -- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway |
25-10-2012, 04:55 AM | #3 | |||
VFII SS UTE
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
25-10-2012, 04:57 AM | #4 | ||
What do you mean modern dohc, Mercedes and Jaguar were selling them in the 1950s.
Considering most petrol engines can't even break 40% efficiency the whole pushrod v ohc arguement is like saying an EA Falcon has better build quality than a VN |
25-10-2012, 05:01 AM | #5 | ||
Brad
Nothing wrong with push rods....
25-10-2012, 05:28 AM | #6 | ||
GM has already made OHC V8's for Cadillac.
Anyway hope this one goes well and Holden get a good version. This new motor has Direct injection and VVT. not bad. |
25-10-2012, 06:20 AM | #7 | |||
25-10-2012, 07:19 AM | #8 | ||
Oo\===/oO
The Gen 3 is one of the most popular V8 ever...compact, lightweight and can make big power...
GM have already played with DOHC...Northstar, C4 ZR1...
25-10-2012, 07:55 AM | #9 | ||
Lukeyson
I wonder when Coyote/Miami will get Direct Injection, and what sort of power/economy improvements are yet to come?
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
25-10-2012, 08:17 AM | #10 | ||
FG Falcon fan
Judge ye engine not by its parts but by its input-to-output. IF a pushrod V8 can pull off respectable economy and power...then go for it.
25-10-2012, 08:23 AM | #11 | ||
450 hp and 450 lb ft is a very formidable and cost effective unit for HSV,
will this be their top engine for GTS or basic for Clubsport? |
25-10-2012, 08:37 AM | #12 | |||
25-10-2012, 08:42 AM | #13 | |||
25-10-2012, 09:03 AM | #14 | ||
holden seems to be stuck in a cycle of drill it out and put bigger slugs in rather than moving with the times . lets face it, this is just a tarted up tractor engine.
to the best of my knowledge there ahasn't been a push rod engine in FOAs line up for 10 years , the last one being the 5.0 windsor lets look at figures GM 6.2L pushrod V8 335 KW Ford 5.0L quad cam V8 335KW Ford 4.0 twin cam I6 310 KW using technology you can have a 4.0 6 that is only 25Kw short of a 6.2L tractor engine
[SIGPIC][/SIGPIC]
25-10-2012, 09:04 AM | #15 | ||
Pushrods for me thanks, they are beautifully simple and smart - you use the space between cylinder banks for the pushrods and camshaft whereas a OHC engine needs to be much wider and taller. You can position a pushrods engine lower down and further back in the engine bay - negating the classic front end heaviness you more often encounter in a OHC V8 car. To put it in perspective a GM 6 litre V8 is 20 cm narrower than a 4.5 litre Porsche V8 and lighter. The GM V8 family is also easy to assemble making long term maintenance a lot cheaper.
If you look at physical size, cost and weight to performance and efficency pushrods can't be beat. |
25-10-2012, 09:05 AM | #16 | ||||
Brad
4L DOHC I6 195 kW GM 6.2L pushrod V8 335 KW Those extra two cylinders seem to be earning their keep lol. Last edited by 99AUXR; 25-10-2012 at 09:12 AM. |
25-10-2012, 09:10 AM | #17 | |||
25-10-2012, 09:33 AM | #18 | ||
Don't forget this engine will be Euro 6 and latest Californian emissions requirements compliant out of the door!
25-10-2012, 09:42 AM | #19 | ||
the 2 best things about these engines, compactness and cheapness,
the plus side for rodders once these DI versions become more popular the older version will be even cheaper. |
25-10-2012, 09:48 AM | #20 | ||
BANNED
Bring back the carburettor,points and the valve radios.
25-10-2012, 09:48 AM | #21 | |||
Last edited by GT; 25-10-2012 at 10:54 AM. Reason: No need for the extra comments thanks. |
25-10-2012, 10:08 AM | #22 | ||
If only we could get this much love for ford products on this forum
25-10-2012, 10:11 AM | #23 | |||
Brad
Another thing you will notice is the people defending the push rod etc. are actually the ones that show some interest in our own product aswell. |
25-10-2012, 10:30 AM | #24 | |||
[SIGPIC][/SIGPIC]
25-10-2012, 10:31 AM | #25 | |||
and the relative ease of manufacture and provision of big capacity. No doubt the FPV S/C 5.0 is a work of art but I sometimes wonder whether a S/C DI VVT 5.0 V8 Chev could be just as impressive.... Last edited by jpd80; 25-10-2012 at 10:39 AM. |
25-10-2012, 10:34 AM | #26 | |||
[SIGPIC][/SIGPIC]
25-10-2012, 10:42 AM | #27 | ||
some just don't get it.. engine is just an air pump.. doesnt matter how it does it as long as it does it well....
25-10-2012, 10:51 AM | #28 | |||
the list goes on but you get the idea, push rods belong in tractors not performance cars
[SIGPIC][/SIGPIC]
25-10-2012, 10:52 AM | #29 | |||
Brad
Push rods are easily replaced. |
25-10-2012, 10:57 AM | #30 | |||
Direct cam action onto the valves with no pushrod tollerances to get into the way. time to move on from the 70 year old chev design i think, stop living in the aussie 80,s lol |
