Old 21-12-2012, 06:25 PM   #1
79FordEsky
79FordEsky's Avatar
Default Air compressor Conversion Help!
Hi,
I am currently converting a 3 phase big air compressor with a petrol engine on it. The engine is a 13hp motor and the pump is a type 30 ingersoll rand. I have had my step dad say that I need a clutch and I do not believe it does. Can people give me a some advice.
Any help would be appreciated. I can provide more details if needed
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 08:35 PM   #2
pcman
Default Re: Air compressor Conversion Help!
you either need a clutch or you need a air release valve, that auto opens too regulate the pressure in the tank, otherwise the tank will possibly explode if you dont switch the engine off
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 09:11 PM   #3
wang
Yes it needs a clutch that is hooked up to a load/unload valve so when it gets to a set pressure it engage/disengage . Otherwise it will just keep building pressure until the relief valve blows
wang is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 10:36 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. Petrol or diesel engine compressors use an unloader valve to stop the comp from working and a governor to control the speed of the engine. when the pressure is high enough the unloader stops the compressor from pumping and tells the governor to let the engine idle. As the pressure drops to the lower switch point the governor brings the revs up and the unloader valve stops working so the comp starts pumping again. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 11:17 PM   #5
79FordEsky
79FordEsky's Avatar
Ok where will I be able to get an unloader valve and governor, Should I try air compressor shops and suppliers or gasweld.
My Ride: -
Check it Out
Old 22-12-2012, 03:23 AM   #6
Mickxr8
Mickxr8's Avatar
Whatever you do , make sure the pressure relief valve is there and works ( should be totally separate from all other hang ons and be on the tank ) .
"You can't fight stupid people - there's just too many of them.The internet: Access to all the world's idiots
Mickxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2012, 09:22 AM   #7
79FordEsky
79FordEsky's Avatar
I already Have a pressure relief valve on the tank the tank has a max KPA of 2027
My Ride: -
Check it Out
