Old 21-08-2015, 03:27 PM   #1
FLOGGED
FLOGGED's Avatar
Default circumference of wheel
Hey guys, very very random question, i thought i would ask here.
i have a mini bike racing tire, im trying to find the circumference so i can set up my speedo.
it is a - 110/50-6.5 Racing Slick
circumference needs to be in MM.
Hope someone can help.
"If Everything Seems Under Control, You're Not Going Fast Enough" - Mario Andretti
2009 Fg Xr6 Sedan n/a 5 Speed Auto - 14.1 @99 MPH
Mods: Redback Exhaust & Cold Air Intake
Untuned
FLOGGED is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 03:57 PM   #2
XB GS 351 Coupe
Default Re: circumference of wheel
Tape-measure would be your friend here.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 04:33 PM   #3
FLOGGED
FLOGGED's Avatar
Thanks! do you know how to messaure it using a tape? cheers
Untuned
Old 21-08-2015, 04:37 PM   #4
Wrap a cloth tape measure around the middle of the tyre, make sure it's fairly firm.
If you don't have a cloth one, use a piece of string and mark it clearly, then measure it.
Old 21-08-2015, 04:39 PM   #5
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
If you have trouble getting a tape around it try marking the edge of the tyre with chalk. Move said mark to the bottom and mark the ground where it touches.
Then move the tyre a single full revolution and mark the ground again. Then measure the distance between the two marks you have on the ground.
This is how I used to setup my Husaberg speedo when using the Trail Tech Vapor. Would be best fitted to a rim and inflated before measuring.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 05:23 PM   #6
SumoDog68
It is 110 mm wide and 50% profile which is 110 (55 mm top and bottom ) plus 6.5 inch wheel which is 165.1mm . Diameter is 110 plus 165.1 which is 275.1. Circumference is 2rp which is 863.8mm.
SumoDog68 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 05:27 PM   #7
FLOGGED
FLOGGED's Avatar
Woah Thanks , i really should of paid attention in maths class.
Untuned
Old 21-08-2015, 05:54 PM   #8
Giant Cranium
PURSUIT 250
Giant Cranium's Avatar
the 50% side wall includes the part that goes inside the wheel right? so that maths may be out
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 05:58 PM   #9
Giant Cranium
PURSUIT 250
just checked you are correct
http://tire-size-conversion.com/tyre-size-calculator/
Old 21-08-2015, 06:42 PM   #10
esppwr
Measure outside diameter then multiply by PI (3.142)
Ed Xr6 Turbo manual, GT3540, 6Boost Manifold, Autronic SM4, 285 rwKw @ 4800 rpm, 4 dead T5's, countless clutches - Now moving on to FG XR6T 6M transplant
2010 Triumph Street Triple R, Q/Shifter & Arrows minus restrictors
esppwr is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2015, 11:00 PM   #11
Mechan1k
Mechan1k's Avatar
Although tyres do have set dimensions ... not all are equal ... but come close to be classed for that size.
For ultimate accuracy though ... it is best to have the tyre in front of you on the rim at the inflated pressure and measure that way preferrably.
Old 21-08-2015, 11:14 PM   #12
NTF6
As esppwr said PIxD (3.1416 x ?)
2017 Mustang GT (Magnetic)
NTF6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2015, 07:21 AM   #13
SumoDog68
Tyre manufacturers publish dimensional data of a tyres they produce mounted on approved rim. Same nominal tyre sizes differ in actual size depending on manufacturer and type of the tyre , pressure , rim width , speed , load etc
Radius of a tyre changes depending on pressure and speed when mounted on a vehicle . Manufacturers will publish both static and rolling diameter of a tyre at 60 km/h ( bit hard for us to measure a rolling tyre ).
Here is the example of a tyre calculator that uses dynamic and static diameter , contact patch size , air volume , tyre comfort suspension value etc.
http://bndtechsource.ucoz.com/index/...alculator/0-20
Old 22-08-2015, 11:54 PM   #14
Crazy Dazz
But Pies AREN'T squared? They're round.
Making Whine from the Tears of Hippies
Old 23-08-2015, 03:07 PM   #15
aussie muscle
aussie muscle's Avatar
wow, 10 responses before someone used their high school maths.
Good on ya esppwr.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2015, 06:20 PM   #16
SumoDog68
Good on ya esppwr.
And tape measure .
