RBS
Old 08-07-2016, 08:58 PM   #1
low_72
Default GTHO Phase 3 Engine
I have an opportunity to purchase a a xy gt replica falcon ute that has genuine numbers GTHO Phase 3 Engine,box,diff and interior.. whats it worth? i dont want to offer to little or pay to much.. its been in storage for 13 years under a house.. so ill need a full rebuild over time..
low_72 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 08:05 AM   #2
FairmontGS
WT GT
FairmontGS's Avatar
Default Re: GTHO Phase 3 Engine
I don't think it's worth much more than you'd pay for a ute which had a normal 351 driveline. The motor is just a curio piece without the rest of the car IMO.
If it's a factory 351/4-speed ute then it's a different kettle of fish.
FairmontGS is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 09-07-2016, 08:15 AM   #3
cheap
Wirlankarra yanama
cheap's Avatar
I'd be more concerned about ensuring the owner has air tight proof that the mismatched car and engine is not part of a numbers/rebirthing scam.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 08:37 AM   #4
The Yeti
The Yeti's Avatar
Engines have been swapped out of wrecked cars since Henry wore short pants, I think a simple title search would solve that concern
Let's face it back in the 70's / 80's if you totalled your GT you'd buy the wreak from the insurer and slot the running gear in to something else with a few mates some steel caned KB and a few thick sausages cooked on a real wood burning BBQ with onions and tomato sauce on bread while the mrs in her flared jeans smoked alpines to keep thin while pregnant as she watched over the little fellers in the blow up wadding pool and the other shealas talked about what the saw on count down last weekend
Happened all the time
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 09:14 AM   #5
Hardtopxb
Once PHASED.
Tell that to owners that don't have matching number HO'os
2006 BF XR8 Bionic.
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 10:04 AM   #6
thefargo
black xb
thefargo's Avatar
don't know what the car is worth, but Yeti's description of the 70's and 80's is valuable
thefargo is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 10:10 AM   #7
Stefan
Stefan's Avatar
It is worth more if it has all the GHO goodies like carburetor, extractors, headers, balance...also if the gearbox is a long shaft top loader, it has the correct tailshaft, diff housing with swayer tabs welded on, detroit locker, 31 spline axles, 2.5" drum brakes.
Yes I'd pay a small premium.....not for the numbers though, they mean **** without the car to go with it.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 10:15 AM   #8
FairmontGS
WT GT
FairmontGS's Avatar
Sorry, I'm not clear on your meaning.
Old 09-07-2016, 10:43 AM   #9
wodahs
wodahs's Avatar
Originally Posted by Stefan View Post
it has the correct tailshaft.
cant see it having original gtho tail shaft as utes are longer wheel base than the sedans
but yes some would pay more for well the fruit that it may have if it has had that stuff fitted but not the numbers as in this case numbers are only relevant to the fruit not the vehicle , and at the end of the day your still only buying a ute mocked up gt lookalike with 40 odd year old running gear
why would you pay a premium for such a motor just for the numbers when you could build a better fresh one cheaper and still have an un matching numbers ute
as others have said the value in the motor will be (if its still around) the owner of the original vehicle but if it was still around why is it missing its motor
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 11:16 AM   #10
Stefan
Stefan's Avatar
XY utes are the same wheelbase sedans??...I thought
The long wheelbase thing was XA on
Old 09-07-2016, 11:31 AM   #11
wodahs
wodahs's Avatar
pretty sure the xy ute and wagon tailshafts were interchangeable but not the others
but it has been 28 years since I had the xy wagon and did the this bolts with that interchange parts from that time period , even had the fairlane front clip fitted at one stage until I tiered then retro fitted the original back
Old 09-07-2016, 12:07 PM   #12
Crazy Dazz
I agree with this.
The reason a GTHO is worth a small fortune is not because its so much better than the next best thing, but because of its rarity and its iconic status. A replica is just as good as an original, but it's NOT an original.
A nice XY ute is getting very rare these days, hence the value, but really you should be paying for condition.
An XY Ute with a HP Cleveland is a bit nicer still, but really that's all you'll be getting.
Sure, if you could find the owner of the matching HO (assuming it hasn't been crushed) they would normally pay a premium to get their matching numbers engine back, but that's about it.
Old 09-07-2016, 08:32 PM   #13
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
Correct, up to XY Sedans / Wagons / Utes / Vans all had the same 111" Wheelbase. The 116" Wheelbase was XA on Utes / Wagons Etc.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2016, 11:08 PM   #14
Express
Bathed In A Yellow Glow
Express's Avatar
I wouldn’t dig deep but I’d throw in an extra carton of cans for a verified ridgy didge phase 3 driveline just for the sake of owning the driveline.
It’d be a good talking point at BBQ’s and it’s an icon in its own right as the HO was nothing without it.
Old 10-07-2016, 01:49 AM   #15
The Nunn
Can't be worth more than 10 k unless the body is pristine,
2016 Everest Trend, Cool White
2006 BF One Ton on LPG
1982 GLX Mustang Notchback V8 Manual
1979 Mustang Indy Pace Car V8 Auto
1968 XR7 Mercury Cougar V8 Auto
2016 XR6T Falcon Sprint (June delivery)#167
The Nunn is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2016, 08:10 AM   #16
low_72
Ok guys.. i purchased it.. now this Ute was from the northern territory and has factory twin fuel tanks? so thats a bit different as well.
Will be home in a month..its been in storage and hard to get out of its location.. its in really great condition.. yes paint will need to be done.. but 3 or 4 small rust spots in the doors and the rear guards.. its so clean for its age..
will post pictures when getting it out..
Old 10-07-2016, 08:45 AM   #17
QLD-Bluey
True Blue
LOL...ahhhhh I can taste the charred ends of the thick snags now!!
QLD-Bluey is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2016, 10:43 AM   #18
FairmontGS
WT GT
FairmontGS's Avatar
Well done. Looking forward to the pics.
