Old 12-09-2021, 04:39 PM   #1
sacko7
Default What forum to get advice?
Hi, I have posted for a few weeks now some questions I have about an XE, I have had a lot of views but no replies. Where is the best Forum to get technical advice? This is my original post.
Hi all, New to the forum and have some questions I need help with. I have a 1984 XE sedan, 4.1 auto and I am converting to a V8. I have been told that once conversion done a RWC and a view by Vic Roads should suffice. Now my questions, I have purchased a 1984 LTD, 351 complete, I have done this as I believe that a lot of the 6 cylinder components will be no good for a V8, I am replacing radiator, water pump hoses etc with new. I know I will have to extend the tail shaft as the LTD is a longer car. Would the LTD have an LSD? I know it is not a 9inch. The LTD has leaf springs and the XE has coil on the rear, the XE has drums on the rear, What is the best way to get the LTD diff and discs on to the XE? Should I run with leaf or coil on the rear or is it too hard to swap ?
Any other ideas or items I should be aware of please let me know
Regards
Sacko7
sacko7 is online now Report Post
sacko7 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2021, 07:36 PM   #2
wodahs
wodahs's Avatar
Default Re: What forum to get advice?
hi and welcome to the forums and i dont know best place to put this but ill try and throw some answers up
i cant answer this as your not in the state im in and i dont know your states needs in such a conversion from 6 to 8 best to start on your gov's website
now your converting the xe to the 8 from the ltd right ! then being the ltd is longer and the xe is shorter youll need to get a shorter tailshaft not longer . either buy 1 second hand or have one made dont attempt to do your self unless you can cut it right weld it right and then balance it
but me id keep the ltd and flip the xe
this part is a big ask and needs a lot of modification to make the leaf spring fit the coil with the bar work , easier to get the right diff to suit from start.
unless they are the same make diff then change the centers fit the disc's to the outers after removing the complete drum set up and fit the vac booster and master from the ltd
but like above but me id keep the ltd and flip the xe as you already have it all in that package
Regards
Sacko7
changing the car from coils to leafs or diff from leaf to coil will more than likely require an engineers cert which will more than likely need some one who can proceed with the job that knows what their doing and the engineer which can become costly
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2021, 10:02 PM   #3
Advice can also be had on Whirlpool, Reddit and Mumsnet, although quality and accuracy will vary!
It may be possible to put the LTD diff internals completely into the XE diff housing - provided the flanges are identical.
The whole job should be done thoroughly, a half-baked conversion as these cars otherwise climb in value, will detract from asset growth.
Is the LTD shell much rusty? Looking out for a sound front cut, from front floor to shock towers.
Old 12-09-2021, 10:10 PM   #4
Jack91
Jack91's Avatar
Yes the inspection should be all as it could've been optioned with a V8.
Dunno about LSD, but pretty sure it will have highway gears in it (lower numerically) not what you want.
An E series rear end (eb xr6) will give you a 3.45 ratio and LSD, with coil springs and discs. Fairly common swap, Google will help you here.
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2021, 10:12 PM   #5
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I also give advice - its **** but at least its free
Old 12-09-2021, 10:32 PM   #6
hayseed
That's All it's Worth,,,,
Having said That.. My(also Free) Advice is to Leave them Both Original.. unmolested Australian Built Cars have appreciated substantially over the last couple of Years & (IMHO) will continue to do so..
However at the end of the Day.
It's Your Car, your Money, Do whatever floats your Boat..
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2021, 11:01 PM   #7
Ratmick
IT Drone from Sector 7G
Ratmick's Avatar
From the Vicroads website:
A person must not modify a vehicle intended to be used on a highway except with the approval of or in accordance with guidelines published by VicRoads. These guidelines are contained
in the Vehicle Standards Information sheets 8 and 32. Depending on the nature of the modification, a Vehicle Assessment Signatory Scheme (VASS) Approval Certificate may be required.
https://www.vicroads.vic.gov.au/safe...ds-information
...specifically No. 8:
Engines
VSB 14 Modification Code LA Modifications listed under section 1.1 and 4 of VSB 14 section LA are considered to be approved modifications when conducted in accordance with instructions and compliance with Standards for Registration are maintained.
In all cases, if the engine is modified such that the resulting power increase is greater than 20% it must be certified by a VASS Signatory under the relevant Code of Section LA.
VASS Contact List here
Ratmick is online now   Reply With Quote Multi-Quote with this Post
Old 12-09-2021, 11:17 PM   #8
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Wrecked heaps of these cars back in the day when they were worth nothing
I would start with checking the ID tags of both cars and posting up the engine trans and diff codes, from this we can work out if your LTD has a 351 engine or a 302, FMX gearbox or a C4, A LSD or a single spinner.
With this information we can work out if you need to change the diff centre or just the brakes, if you need to get a tailshaft made or just change the yolk, it is a job for someone with a bit of mechanical experience, but not impossible for a first timer with a bit of help from people who have done it before.
Old 13-09-2021, 05:25 AM   #9
sacko7
Thankyou people for your replies and comments and I have taken all advice on board. Unfortunately there is not a panel or sill on the LTD that is not rusted out. I know most things are fixable but this lived out in a paddock for years and the interior is the same. Only the running gear appears salvageable. The Xe has been restored and repainted twice in its life and is fully registered at the moment. On your advice I will contact Vic Roads for their advice. Many thanks again
Sacko7
Old 13-09-2021, 07:27 AM   #10
Dr Terry
How can a 1984 LTD have a leaf spring rear end.
AFAIK the last leaf sprung LTD was the FC series (1979 to 1982).
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
