Old 03-09-2007, 05:12 PM   #31
genebaby
Abuser of Charvels
genebaby's Avatar
Happened in my XF Ghia, but my friend was driving it and he was not used to the fairly aggressive way the cruise would try to build up speed. Happened to be a bit drizzly, going up a slight incline on the way to Sydney. Car went sideways, luckily nobody was coming the other way at the time. Funny afterwards, but not at the time.
No problems with it in the BA but I can't remember using it in the wet really.
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 06:15 PM   #32
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I think it is a fair call Norm, as people have stated above. I have experienced a couple of scenarios that validate the "trigger" conditions for me.
1. Hitting a deep puddle slows the car down. Regardless of aquaplaning issues, it is like putting the brakes on. The most recent example I experienced was driving along a road in the dry and coming across a small section of water over the road in a dip. It wasn't enough to cause any loss of control but did knock a few km/h off the car's speed, which would be enough for the cruise control to call for acceleration.
2. Hill and corner combination. Again this was in the dry, going up a short yet sharp hill with a bend over the top, the reduction in speed triggered a burst of acceleration just when I didn't really need it turning into the corner.
I don't have a drama using the cruise control in normal rainy conditions but obviously you need to be aware of the road conditions just as you do if not using cruise control. The difference is the behaviour of the cruise control is another factor to be aware of.
Old 03-09-2007, 06:58 PM   #33
Agent86
Not so low, not so slow.
Agent86's Avatar
Originally Posted by MO
Perhaps ppl should learn to drive..not steer!!!!!!
I find this vaguley insulting and a very broad comment that has no use other than to show ignorance.
Im a professional driver ( semi ) after 14 hours of Battling traffic around melbournes roads, its somewhat of a relief to be able to whack the crusie on and dawdle home.
I can drive, and i'll happily prove that to anyone.
May not be an UBER driver, but im good enough.
Agent86 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 08:15 PM   #34
TwistedEL
TwistedEL's Avatar
I use cruise control when the roads are wet, but not when there are puddles or the rain is seriously coming down.
If you have any doubt that it could happen just slip your auto into neutral next time you have cruise engaged...
Old 03-09-2007, 08:15 PM   #35
MO
MO's Avatar
AND YOU missed the point these days the young are taught how to get a license....not how to drive.
BIG BAD MISTAKE!!!!
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 08:16 PM   #36
xtremerus
FG XR6T trayback
xtremerus's Avatar
If you use the cruise control as the name suggests,that is, when cruising, there is no problem, wet or dry. The scenario of going fast into an uphill corner in the wet in an auto car can have problems of changing down a gear whether cruise is on or off.
Cruise Control systems do not snap the throttle open when it detects the speed decreasing. They seem to react quite slowly. Aquaplaning in a few puddles does not give enough time for the cruise control to react.
My 2 cents worth.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 08:22 PM   #37
MO
MO's Avatar
And using cc costs you in petrol...it uses more.
FORD RULES OK
Old 03-09-2007, 08:27 PM   #38
xtremerus
FG XR6T trayback
xtremerus's Avatar
Another urban myth???
yes
Old 03-09-2007, 08:32 PM   #39
MO
MO's Avatar
yes
NO have proven it...
FORD RULES OK
Old 03-09-2007, 08:36 PM   #40
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
yes
You can call that busted. I’ve driven many trucks mostly fitted with CAT engines that certainly use more fuel on cruise when not on a fairly level road surface.
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 08:37 PM   #41
xtremerus
FG XR6T trayback
xtremerus's Avatar
In hilly country, you may be right.
In flat western country I may be right
Old 03-09-2007, 08:46 PM   #42
MO
MO's Avatar
Wrong think about how many variable changes cc makes hills or not...think about it.
just for info lived in the Top end for 16 yrs...capiche..
FORD RULES OK
Old 03-09-2007, 08:46 PM   #43
DBL15
love being blown
DBL15's Avatar
My 2 cents worth.
ok let me tell you if the car/ute is powerful enough and you have cruise control set at a speed limit then hit the brake for any reason it turns off but stays set you hit resume cruise and it can and will break tracktion no problem at all and yes i am pushing decent RWHP but still a person not knowing what it can do would get a shock
i drive with cruise on every trip from 70km per hour to 110 km per hour wouldn't dream of having a car/ute without it
in saying I never use cruise in the wet for the aqua planning reasons all ready mentioned.
GT-P 2003 + XR8 Supercharged Ute 260+ BOSS : : :sm_headba :
New PB 12.4 @ 108mph : :
www.xrclub.com.au
DBL15 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 12:07 AM   #44
Van D
Van D's Avatar
Yep, it's happened in our BA before. Over the crest of a hill whilst it turned, the cruise decided to kick it at just the wrong time and the back lost traction. Didn't come unstuck bad, but I can see it happening.
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 03:27 PM   #45
Sprint347
Tickford
Sprint347's Avatar
i will only ever use cruise crontrol on a dry, sunny day on an open road... any other application i dont feel 100% in control of the car
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 07:02 PM   #46
Agent86
Agent86's Avatar
BIG BAD MISTAKE!!!!
And where did the comment of young come from?
im young (26) and i have had NO formal training and SFA informal training, even though i drive HC vehicles.
take that limited perspective and widen it.
Where, even in a prfessional driving course do they discuss in depth the ins and outs of CC?
Yes i think every driver shoudl be made to pass an advanced driving course before being allowed to retain their licence, no matter the endorsemnts on it.
I know how far cars have come in my parents and grandparents lifetimes.
They have had NO education on how the handling characteristics have changed, no instruction on the changing laws and so on.
The problem that is our roadways and its users has no easyquick solution, therefore noone wants to touch it cause the benifits might fall outside their terms in power...
