Old 06-10-2012, 08:51 PM   #61
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: What mods have you done that failed
Originally Posted by BPXR6T
More likely you got a crap soft set of rotors. I've ran EBC green stuff pads a few cars now with slotted RDA rotors and had insignificant wear.
Funny you say that as they were RDA slotted rotors.
But then again I suspect there was some sort of brake issue with that car anyway, they were always spongey as hell and always needed a decent shove to get the thing to really slow. Flushed the fluid, fitted new pads and rotors and everything else but it still made no difference.
Old 06-10-2012, 09:23 PM   #62
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
First car, N13 Pulsar, I fitted one of those fans you stick in the intake pipe that are advertised to help atomise the fuel and bla bla bla. One of my friends actually bought it though so I never kept it long.
Same car the rear muffler came apart at the front so had the local Carline fit a 2 inch cat back. The ******* didn't even change it at the flange, and had the new 2 inch section welded onto the last foot of the old exhaust and looked like the apprentice had done it. There was still welding wire hanging off. That car became too much of a hassle to keep registered before I could do my suspension and CA18 swap.
Wasted a few grand on an EB Falcon trying to put a V8 into it. Should've stuck with my original plan of putting in a DOHC six, but I found an $800 V8 Fairlane that I thought would have everything I needed. I bought an Explorer manifold and GT40P heads before I did enough research to suggest they're still pretty restrictive, and before I gave up for good I had about $15k worth of planned engine, transmission, suspension and brake mods.
The BF I had a Hurricane/Redback 2.5 combo that I wasn't happy with how low it hung. I bought a 3 inch 100cell cat to put in and took it to the 2nd most local Carline this time. My discussion with them over why I went with that cat, believing it to flow better, mustn't have explained I was still after a performance system and I ended up with a press bent centre section (as we agreed a smaller muffler would allow the exhaust to be tucked up more and i was told Redbacks were pretty quiet) that probably performed worse. I couldn't simply refit the old centre as they had cut out the old centre right behind the muffler as opposed to undoing the flange some 6 inches further behind.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2012, 09:28 PM   #63
puck_lindsay
Re EBC Greenstuff - I used the in both ELs and theyve been excellent every time. Might be rotors? Incorrect fitment? Dodgy batch?
Done a whole heap of stuff, this is only what I can remember:
Putting 2 12" boxed fusion subs in the boot with a massive amp...all unsecured. Bounced around like crazy, number plate rattling away.
Gutting a perfectly good high flow 3" cat because my car wouldnt rev properly. Droned like crazy. Turned out to be the fuel filter.
Putting a second hand 2.5" exhaust on. muffler had rusted from the inside out, middle pipe mustve gone under the wheel on the highway but the whole middle section was yanked cleanly away at 100kph. Exhaust note after was impressive.
Cuting holes in my intake everywhere for "better flow"
Trying to change my own brake pads a few hours before driving from esperance to perth. Somehow managed to destroy one of the brake pistons and something else as well. Had to brake by shifting down gears and then handbrake. Didnt put the wheel back on properly either, nuts were halfway off by the time I got to ravy.
10 FG G6ET - Rocket-powered lounge suite.
430rwkW/950Nm.
puck_lindsay is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2012, 10:54 PM   #64
GCRXR6
GCRXR6's Avatar
Originally Posted by Mr Hardware
parcel.
Ha ha.. by time he was finished with the snips and angle grinder ... it was a "partial" shelf.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2012, 03:16 PM   #65
matty88
Buying a $100 second hand engine and trusting the seller
matty88 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2012, 03:37 PM   #66
GUTLES
Adam.
GUTLES's Avatar
Purchased a Polariser, didn't work.
Purchased one of those Fuel Saving Chips that you put behind your seat, didn't work.
Only joking haha
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw
2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater.
2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob.
GUTLES is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2012, 07:05 PM   #67
noflac52
noflac52's Avatar
When I was 17 I cut the roof off a 4dr hillman with a hacksaw, instant convertible, no other mods and drove it around the block. Half way around the back doors fell outwards at the b pillar. No problem lifted them back into place and tied a piece of rope between them across the car to stop them falling out again. Drove on and by the time I got back home there was a definite sag in the middle and the end of the gearbox and front of the tailshaft were dragging on the ground until the tailshaft fell out as I went up my bumpy driveway.LOL! Total fail!
Lesson learn't there's more to making a convertible than just removing the roof.
noflac52 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2012, 07:41 PM   #68
Stazza_Brendan
Stazza_Brendan's Avatar
Brother had a EL wagon that he didnt really look after.
Came home one day and he said the muffler was making weird noise.
I go outside and see the rear muffler has rusted out and the pipe coming out of the rear muffler was only just held in place.
A well placed kick from my work boots removed the offending pipe and he drove it for another 2 years with just a hole in the back of the rear muffler. No more rattling noise though :p
Bought some lowered AU front springs to put in my BF ute. Ended up Waaayy to low and they came out the next day.
After my Starion was written off i needed a car on the road ASAP. I had a Cordia Turbo in the backyard id tinker. Roughly bogged up the rust and sprayed over it, got a new windscreen and got a very very lenient roadworthy :p
Had lowered rear springs i had laying around, cut the fronts to suit. Had a cannon on the back to replace the stuffed rear muffler. Bought another bonnet for $3 and put some sierra cosworth style vents in it and a fake wrx scoop just above the BOV. Was built on purpose to be a ricer. Put an intercooler in the front, wound the boost up to just under fuel cut (14psi) and drove it for ages until the cops said "if i see this driving around again you wont have a licence", deregistered it a week later after buying a new Starion.
Was made up from cheap/2nd hand parts and a fun thing to drive, and the motor just wouldnt die, although you didnt do oil changes, just topped up the oil regulary and changed the filter every 6 months :p
Seduce BFII XR6T Ute
ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw
Stazza_Brendan is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2012, 08:04 PM   #69
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Being 17 I wanted a 'performance' exhaust... "Straight through is what you want" says a mate of mine, "Let's the exhaust gases get out quicker, makes you go faster too!"
So a pair of tin snips and 10 minutes later I had an '(cut)open straight through middle muffler'... straight onto the road below that is, sounded like a fart breaking the sound barrier through a pair of jeans.
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2012, 09:39 PM   #70
TheZHLANE
TheZHLANE's Avatar
Altezza tail lights -.-'
RIDES
76 ZH Fairlane 500, Mushroom Beige, Brown vinyl roof, 351 c4 13.361 @ 104mph 2.001 60ft 208rwkw
ZH BUILD
TheZHLANE is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2012, 09:49 PM   #71
XB GS 351 Coupe
I had a Mark 2 GT Cortina years ago, thought I do the right thing and took it to Pedders for the whole package, I was on apprentice wages and it cost me about two weeks wages, poor thing was never the same, the ride was terrible and handling was worse, could not really afford to change it back as the old springs and shocks got scrapped so sold the car
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 12:41 AM   #72
XRDeeze
UTRIED
XRDeeze's Avatar
Originally Posted by Nikked
Too much stress on all the other componants...
thanks for the heads up Nikked!
my failure? "moding" my front bumper by making - and hoping - it all stuck together with a bit of duct-tape, here and there. (I smashed it running into a gutter). just a couple of days later, the front end gave way. forcing the right foglight to fall out and dragged it all the way home, still got it on today.
BA XR6 03
Townsville Drag 1/10/11 PB: 15.34 @ 91.09 mph
XRDeeze is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 01:30 AM   #73
Cambo351
Jag built with Ford money
Cambo351's Avatar
I put a pair of spotlights on the front bumper of my NC Fairlane.
The car was lowered with Koni shocks & Lovells springs (cost about $2K at the time)
If you drove nose first down a steep driveway the spotlights would catch at the bottom and get pulled down.
Get out, lift them back up, keep driving...
Ex: AU XR6, Mondeo ST200, AU3 TE50, NC Fairlane 5.0, XE ESP Turbo, XY Ute, XD ESP with a 351
Also have a Land Rover, and another Jag, somewhere...
Cambo351 is offline   Reply With Quote Multi-Quote with this Post
