Old 14-09-2006, 01:21 AM   #1
HyperFlow79
Default Genuine GT xflow motors???
Hello People.
How does one distinguish a genuine 'GT x-flow motor'? Is it as simple as the block number? if not, what number(s) would someone need to positively identify the motor? My mate has his eyes on a block. Can any one help us out? Or point us in the right direction?
HyperFlow79 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 10:20 PM   #2
mk2-71GTL
Default gt engine id numbers
67/68 1500 gt prefix is CH
68/69/7O 1600 gt prefix is CN
HOPE THIS IS OF SOME HELP :1syellow1
mk2-71GTL is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 04:46 PM   #3
crispymk2
crispymk2's Avatar
Not positive on the GT's, but mk2-71GTL sounds on the money, as for general 1600 block ids 711M is the thick wall casing and AA at the end is 1300 while BA is 1600
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
crispymk2 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 09:24 AM   #4
whooligan
whooligan's Avatar
I'm pretty sure most of the work on the GT motors is in the head anyway. The GTs had the 711M block, but so did all the later Mk 2 Escort x-flows. I have a GT engine in my Escort van "supposeably" out of a Mk 2 GT Cortina. It make sense, as the gearbox attached is the close ratio one out of a Capri (with cable clutch.) The Engine number starts with V89.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 09:52 PM   #5
HyperFlow79
thanks,
I'll check out some numbers once they clean it up. I've been told not to worry coz you can actually mod these heads to exceed GT spec. If, it's not already obvious, yep i'm a newby...to all this..
Old 14-10-2006, 09:33 AM   #6
whooligan
whooligan's Avatar
Originally Posted by HyperFlow79
thanks,
You've got to start somewhere. I've been pulling old Fords apart since I was 16 and I'm still learning 20 years later.
