Old 12-01-2007, 06:11 PM   #1
bertis
bertis's Avatar
Default Gearbox for my turbo eb
I am a little confused on what to get for my turbo eb.. I see people on here pumping out more rwkw on standard t5's... just how nice are these people running a t5 behind a 300rwkw turbo'd falcon....spoke to a couple of people and it was a 50/50 on a t5z lasting in my car
My mate is willing to give me a tremec 5spd gearbox. we have no idea what it is or what its out of??? it has a tag with the following
wr2a 7009-aa
557-001 4498
dont think it has much else written on it.... might be out of a au or ba...
if anyone has any info on what this box is and how hard it would be to put into a e-series that would be great
Brett
Old Car
EB series 2, Vixen red with blue perl, custom body kit, lowered, sweet custom interior :hihi:, ported head chambers, T3/t4 hybrid turbo, log manifold, intercooler, vortech 12:1 rising reg, Walbro 255, thermo fans, redback exhaust, 3.45 LSD,Stage 2 BTR95le built by DTM, pioneer 680MP, 2x pioneer 450w subs, response class D 820w amp
13.10@105mph on 10-11psi
New Car
Standard FG XR6T with Cobalt gauges so far.
12.85@109mph on STD boost
bertis is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 06:20 PM   #2
snypereb
[EBGLT]
snypereb's Avatar
All depends on what you prefer and how much you want to spend and how much power yu car has. T5's are heaps of fun but will a basic one be able to handle the power of the EB?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 06:41 PM   #3
John_LS1
wr2a is an AU part number so its out of an AU (duh) would need to find out if its from a 6 or an 8 because one from an 8 wont fit the 6 without modifications...
Old 12-01-2007, 06:56 PM   #4
bertis
bertis's Avatar
should be around 220-250rwkw once the wolf goes in.... just under 200 atm i'd say... unless the auto's in a bad mood..... I seen a post about a guy who had his t5 strenthened for $1800 which sounds good to me but i'd like to know what others think about this...
I have done some reading on what other turbo users have and most seem to have gone with c4's which I'm not interested in because I do so many highway k's.....
I might end up going with something like a TKO.... or i'm very interested in the t56 which doesnt seem to be as expensive as people believe.... but then I dont know whats envolved after pruchasing the box....
Old Car
New Car
Old 12-01-2007, 06:59 PM   #5
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
The tremec might be hard to fit in if it's from an AU.
Just get a strengthened T5Z from mal wool automotive in QLD for around $2200 changeover with a standard T5.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 07:40 PM   #6
TUFED6
TUFED6's Avatar
Don't bother with a T5Z, they're barely any stronger. They're already on the limit in a standard BA XR6T with 240kw IMO. Hence the T56 in the BA2.
Get a BTR rebuilt with some stronger internals. Other than that, T56...
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 08:06 PM   #7
Rollin
Rollin's Avatar
All T5s FTMFL.
Don't bother with any of them, even the strongest ones will struggle at your power output.
Find out for sure what the box your mate has is, and if it's in working order.
If it won't fit straight into your car, give Mal Wood a ring and see if they sell a kit to fit it, or would take it as a trade on a TKO or something.
T56 would be great (get a whole setup from a stacked XR6T or something?), but you need to convert to hydraulic clutch, make a rear gearbox mount and custom tailshaft.
Then you have to get the speedo to work somehow...BA use a wheel speed sensor signal to run the speedometer, E series use a transducer on the back of the box...I'm not sure how to overcome that little problem yet - Ask Mal Wood if you end up giving them a ring!
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 08:11 PM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
what ever y6ou go for it will end up costing $$$ malwood want nearly 8000 for a full t56 set up. not to say it isn't goos just a bit $$.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 08:15 PM   #9
dansedgli
dansedgli's Avatar
TKO 600 conversion is only $5500 ish last time I checked.
Im lucky I scored a TR 3550 with my car for the nice sum of $4300. It was already turbo too!!!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 08:23 PM   #10
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
I hate you dan!!!!
damn compliance plate!!
Old 12-01-2007, 10:08 PM   #11
oneredED
need more boost
oneredED's Avatar
I gave some help to my step-brother when he converted a VPSS (big power N/A motor) from a T5 to a T56 from a Gen III, and let me tell you, it is a pretty huge job. The pedal box modifications alone to allow for the hydraulic clutch is a nightmare. Custom tailshaft, bellhousing, starter motor, exhaust, pedal box, combined with a (decent) new clutch, the costs all add up very very quickly.
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
