Old 13-01-2007, 09:28 PM   #1
EBIIXR6
EBIIXR6's Avatar
Default Walbro Intank Fuel pump
Going in my Eb
PUMPGSS342, has anyone fitted a walbro intank themselves? is it much of a task?
Is the standard pump intank ?
Thanx guys
93' EB II XR6 factory manual
Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02:
EBIIXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 09:32 PM   #2
needfordspeed
It's easy as, the botton of the cradle needs a bit of modification but it's pretty straight forward, you'll see what you have to do once you pull it out and compare it.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 10:11 PM   #3
EBIIXR6
EBIIXR6's Avatar
thats what i like to hear.. thanx needforspeed.
also... what lb/hr are my injectors? stock eb xr ones...? are they the same as the gli?
Old 13-01-2007, 10:21 PM   #4
needfordspeed
Yeah they're the same as normal ones 19lb IIRC.
