Old 19-02-2007, 01:37 PM   #1
xertia
xertia's Avatar
Default Steering problem
Hi guys, been a long time reader of these forums but never actually posted! Have recently noticed on my 98 AU Forte the steering has started making some awful creaking noises when I move the wheel left to right. Seems to be mainly when parked and does it whether the engine is running or not. Does this mean my rack is on its way out or just in need of some kind of servicing? Also, as I know f*all :togo:, what sort of cost would I be looking at to replace the rack if needed?
Thanks.
xertia is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 01:44 PM   #2
Mechan1k
Mechan1k's Avatar
Could be a number of things ... do you have plenty of fluid in the Power Steer reseveroir ... are there any leaks in the power steering system. I could be just air in the system.
Although on another note I had creaking and clunking coming from the front right .... and it was an upper ball joint that was a culprit .... i had it replaced ... noises all gone.
I am suspecting the ball joint. Any suspension place that does safety checks can tell you and show you as well. It also affects steering performance as well as the control arm moves as well ... it's also unsafe as well.
Best bet ... get the front suspension checked out and find where the problem lies.
Old 19-02-2007, 02:00 PM   #3
Schwinn
Old Hack
Schwinn's Avatar
I had a problem like this on my old ED Fairmont, was the firewall bearing, but some WD40 on, no probs!!!
would be nice if ALL Ford issues could be fixed with WD40...
Schwinn is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 02:02 PM   #4
Mechan1k
Mechan1k's Avatar
Works on squeaky/grabbing window guides :hihi:
Old 19-02-2007, 02:10 PM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
and wet plugs !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 02:16 PM   #6
xertia
xertia's Avatar
Thanks for the quick replies! It did kind of get worse when I replaced the power steering fluid, how do I get air out of the power steering system? When I replaced the fluid I just ran it for a few mins with the cap loosened off on the reservoir and steered full-lock left to right a few times... also would air in the system reproduce the same creaking with engine off?
Old 19-02-2007, 02:28 PM   #7
mattp
mattp's Avatar
I forget the details, but it's quite common for the 18mm nuts on the steering rack (?) to creak and moan, they can be lubricated and this fixes the problem. Try doing a search on the issue. Mine does it a little bit occasionally, but not enough to inspire me to get under there and fix it.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 04:43 PM   #8
GK
Walking with God
GK's Avatar
Isn't that the truth! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-02-2007, 04:58 PM   #9
AU dude
Flying high...
AU dude's Avatar
i found that those 18mm nuts on my au were lose, so i got out the torque wrench, and torqued them up to specs. it fixed my problem...
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
