so im heading off to heathcote this weekend for some qtr mile action...
it will be my first time on a strip, you guys gets any tips to get off the line quickly and a half decent 0-60 time? |
Flying high...
How many runs do you want to do?
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
ill be doing as many as i can. gates open 11 - 4. my mates tells me to expect about 15-20 runs depending on how busy the track is
if its an auto and has abs pull the wiring connector off the abs module, i found it easier to stall up and take off harder. but the best thing to do is just practice and see what works best for you and the car. I have a XR8 Auto and found if i let the wheels spin off the line a bit it gave me a better time
MR INCH
Just slidin'
I think his is Manual.
MD Mondeo - For the family
NP Pajero - For the adventure |
yeh 5 speed
my pointers are:
drop ur tyre pressure down to 27 psi, and launch it at 4000rpm shift as quick as u can! flat shift 3rd to 4th (involves real quick shifting)
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
More Boost
MR INCH
Dont ride the stock clutch too hard, it will get hot and slip.
#10 | |||
Boost Addict
in general you can drop up to 6 pounds of pressure out of your tyres compared to regular street pressure. if you go toolow tyres start peeling off your rims and they kick ur *** off the track. as for launching: depending on the track conidtion and tyre condiction and compound a laucnh between 2500 and 3500 gives you enough torque to get off the line qickly and get up into the rev range. you want a good mix of little slippage and full traction and most possible rpm. that formula of course again depends on cam shaft and mods. I also like using my handbrake to limit slippage. quick shifting from 1st to 2nd and 3rd to 4th is easy, however take your time and concentration for 2nd to 3rd as its the most important shift to get right and most likely to bugger up. i got my 60 footers well below the 2sec mark, but i had some very nice sticky tyres and i was racing at a drag meet and nice tubbed mustang lied down some fat tracks for me. i started with 2.2sec 60 footers before getting more and more involved into racing. also as a comparison my AWD ran 1.5sec 60 footers on my auto box ... yet to trial my manual without breaking it.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
