93 ED Futura
93 Ford EB Futura
Ok, went to start my ford, nothing, Battery flat. Then spent 40 minsutes trying to jump it, nothing. New Battery. After i put it in the hazard lights came on and stayed on, not blinking, just on. I had a hole in my radiator overflow and there was some dried coolant around the battery so i cleaned it up and lights went out. Went to start, (all dash lights working, headlights ETC) NOTHING. The starter wont even turn over. just a "Click" when i turn the key. Whats wrong with my baby? PLEAAAAAAAAAASE HELP. |
ED_Ghia
ignition coil maybe?
does your car turn over? check to see if any spark comming through the plugs? chuck a multi meter on the starter engine to see if theres a current flowing through it? |
The one and only
If yo post it in here -->http://www.fordforums.com.au/showthread.php?t=107608
You don't need to post in The Pub
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
![]() Join Date: Dec 2004
Smartlock? (got an immobiliser? "unlock" the car with the immobiliser, not just your key)
Methinks you have an ED as well, Futuras didn't come out until the ED range. A hole in the rad reservoir sounds a tad concerning! Could you describe it better for us? |
93 ED Futura
Ok its a 93 ford futura, auto, sedan.
I had a really small hole in the overflow tank, anyway i left the car for 3 months in a carpark (it was running perfectly) So as i said went to start it NOTHING, new battery, then starter wont even turn over. The smartlock light is doing its normal thing, when i take key out it flashes then when i put it in it goes out. Im stumped |
93 ED Futura
I had a look at the ghia5l thread, and that exactly like mine, except auto.
ANY ideas why the F#$K it wont even turn over? Is there a way i can see if the starter is working |
new ford fan
check for corrsion or any build up dirt on power lead going to the starter motor mine did this once. i cleaned it up and was as good as gold hope it helps
cheers matthew
![]() ![]() ![]() daily: 1996 ef auto,lowered,2.5" exhaust,extractors,17" mags,pod filter. project: 1988 ea 5 spd,body kit,bonnet bulge,lowered,lsd,2.5" exhaust,17" mags,eb tail lights and boot,fairmont ghia seats . coming soon full ef fairmont interior,ef motor,ef thermos,ef diff,ef handbrake and a respray possibly blue print or acid rush. |
93 ED Futura
Nope all wires look fine
ay? What thread? The one in my sig? (that won't help you unfortunately :P)
