Old 23-07-2007, 08:31 PM   #1
nob92@
nob92@'s Avatar
Default Au sr headlight ????
hi guys got a good question how do u take apart an au series 3 falcon sr headlight???? i was driving home last nite and blew a bulb, .... literally blew the *** out of it. glass from to breakfast inside it. i don't wanna spend any more money as the headlight is brand friggin new.
nob92@ is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 08:53 PM   #2
onfire
onfire's Avatar
Iv got a feeling you could probly open it from the back of it. Be careful thou.
onfire is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 08:57 PM   #3
nob92@
nob92@'s Avatar
i thoght u could heat the rubbery gel and it comes apart cause ive seen au's with jet black suurrounds as if theyv been painted.
Old 23-07-2007, 09:30 PM   #4
kenz
BOSS Pilot
kenz's Avatar
I pulled mine apart the other week to do the black bezels. Some people say put it in the oven others use heat guns etc. I used a hair dryer because thats all I had and the oven was too small. Just basically heat up the black glue around the outsides and pull it apart then heat it up again and melt it back together. If you're using an oven be careful not to melt the headlight :
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 07:27 PM   #5
nob92@
nob92@'s Avatar
any one else got any sugestions? i wanna do somethin on the weekend.
Old 24-07-2007, 07:32 PM   #6
bodes-sh
this is your only option to get the light apart, simply because the back of the light is moulded, then the front / lense stuck on with silicon type stuff
either that or take what's left of the globe base out and shake it till the rest comes out....if it all comes out that is
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 08:48 PM   #7
chief
FTF Club Moderator
chief's Avatar
Speak to The Dok. He owns and runs the headlight hospital and will be able to help you out.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
